RWHP was 418 Hp & 373 ft lbs TQ
Net was 590 hp / 530 ft lbs TQ
Gross was 710 hp /636 TQ
this will substantially beat up the 500+ Shelby mustang as he has dynoed those as well , the mustang will put down about 388 to the wheels & we hit 416 so almost 40 higher & with more tq as well , the best part is it is all under a stock 68 RR hood , no scoop ,nothing ... beware
Yes it is typical to see that loss from RW - Gross HP with the Mustang dyno , the mustang is the stingiest dyno as far as actual #s but has amazing repeatability
the car was a 68 RR with 727 Auto & 4.10 Dana with 4 wheel disc brakes & full Multi port EFI , 1200 CFM T body & 58 lb / hr injectors
I will get results fot the 512 B1 monster once we get it running , it will likely be in the Oct time frame
