Author Topic: Auto Tranny Cooler Questions  (Read 951 times)
Offline JeffAARy
  • Orange Mopars Drive Me Wild
« on: July 10, 2008 - 01:22:15 AM »
My 71 has an auto tranny cooler.  Not sure if it is stock or aftermarket, but I'm doing the Keisler 5-speed upgrade so it has to go.   I usually only deal with manual trannys, so forgive me for asking, but is ATF running from the tranny to the cooler or is coolant running from the cooler to the tranny?  It is plumbed as follows (could be reverse of this also): line 1 goes from tranny to radiator, line 2 goes from radiator to tranny cooler, line 3 goes from tranny cooler to tranny.
When I go to pull the lines out do I need to have the radiator drained to prevent coolant from spilling out, and/or do I have the same issue with tranny fluid (probably a moot point since I need to drain the tranny before yanking it out anyway)?
Thanks in advance.
-Jeff
Offline 71chally416
    • The Streetwalker
Re: Auto Tranny Cooler Questions
« Reply #1 on: July 10, 2008 - 01:40:37 AM »
Just unhook the lines from the radiator. The tranny fluid runs through the radiator, not the other way around.
Believe it or not, one time when I was a kid I saw this guy pouring ATF into his radiator inlet. I asked him WTF he was doing and he said that was how you filled it. He pointed to the lines at the bottom and said the tranny fluid was heavier than water, so it would sink to the bottom and go to the tranny though those lines. I wish I was making that up.  :screwy:
« Reply #2 on: July 10, 2008 - 02:42:53 AM »
 :smilielol:
« Reply #3 on: July 10, 2008 - 06:15:35 AM »
 OMG!!   :roflsmiley:
Offline MrMopar440
« Reply #4 on: July 10, 2008 - 06:36:48 AM »
Sometimes you just have to smile and walk away :roflsmiley:
Offline 71chally416
    • The Streetwalker
« Reply #5 on: July 10, 2008 - 11:06:01 PM »
A least his water pump was well lubed  :smilielol:
I think his buddies were screwing with him. They told him to put it in there.
Offline RaptorF229
  • A work in Progress
« Reply #6 on: July 11, 2008 - 12:21:47 AM »
Thats almost as bad as the guy who put sand down his intake to port it. :smilielol:
