Hey guys and gals hope eveything is going good for everyone. OK my situation is when I drive my car and it heats up it stalls out. I can start it up if I hold the gas pedal in but if I let it go back to idle it will die again. Also if it cools off 15-20 minutes it will start up fine and run till it heats up again. The entire fuel system is new from the tank to the carb. Also the ignition system is all new. Any ideas on how to fix this problem.
383,727, BG Mighty Demon, New ECU, ballast and engine harness also .
Thanks everyone in advance. I have not had a problem solved without you.
