Author Topic: 1968 340 with X-Heads  (Read 1690 times)
Offline Schwep
« on: July 14, 2008 - 01:39:03 PM »
1968 340 block casting date 6/17/68. Fresh rebuild bored .030 with factory forged crank, balanced rotating assy and all machine work completed by Wheeler Racing Engines. Hydraulic Cam w/ .465 lift 280 duration. Heads have standard port w/ polished chambers, new valve guides, new springs, retainers, etc. 9.37:1 static CR. Too many new components to list. Documented assembly with receipts and complete build sheet available...
$3200 F.O.B Centerville, MN
PM or email tims@arrowtank.com
SALE PENDING...
Thanks cuda-challenger!
« Last Edit: August 27, 2008 - 09:25:15 PM by Schwep »
Offline asm74
Re: 1968 340 with X-Heads
« Reply #1 on: July 14, 2008 - 03:05:33 PM »
Looks awfully nice.  What's the estimated output?
73 Challenger
« Reply #2 on: July 14, 2008 - 03:08:34 PM »
What pistons are in the engine? What rings?  Are the heads equipped with new valves too?
Offline Schwep
« Reply #3 on: July 15, 2008 - 12:05:01 AM »
See attached build sheet...Not listed but, new exhaust valves - intakes measure fine
Estimated HP - The head chambers (believe it or not) came in around 75 cc.  So they could be milled a tad to bring up CR and still have plenty of P-V clearance.  Also a fairly mild cam by today's standards.  I would think with this cam, these heads, intake, headers, and the right carb maybe 365ish HP  :dunno:
The motor is such a sweetheart I didn't want to touch the ports and ruin it for someone who wants/needs stock ports.  Chambers were polished to reduce chance of detonation with pump gas fuel and not necessarily for performance enhancement.  All the machine work is "dead-on" and every single nut, bolt, and thread cleaned by hand.
This motor has been in my possession and resting inside for 24 yrs...Now it's screwed together and waiting for a good home!
