Author Topic: Going to the track saturday.....  (Read 1783 times)
nivvy
Re: Going to the track saturday.....
« Reply #15 on: July 20, 2008 - 10:45:11 AM »
my e.t. poll dissappeared  :clueless: dominator was givin way to many poblems... couldnt get a good run in...... i will post a video later at least...
okay i see they moved it to Classic Cudas & Challengers Galore and no options were there for people to choose... oh well had too many mechanical issues and couldnt even get a good time in... best was 11.51 and the dominator was breaking up on the big end...   :horse:
« Last Edit: July 20, 2008 - 10:52:32 AM by StRoKer »
Offline FJ5_440
  • Wisconsin
« Reply #16 on: July 20, 2008 - 12:07:51 PM »
Maybe you should switch to an Edelbrock carb!! :poopoke: :smilielol:
** Shane **
nivvy
« Reply #17 on: July 20, 2008 - 12:12:15 PM »
that was actually funny.........  :smilielol:
« Reply #18 on: July 20, 2008 - 12:12:56 PM »
Kinda sounds like low fuel pressure stroker or weak plugs from running rich
nivvy
« Reply #19 on: July 20, 2008 - 12:14:56 PM »
the fuel pressure was at 7psi as holley recomends... new plugs... but could have fould also as i richened it up on the secondary progressive linkage getting up on the converter.......   :misbehaving:
was 95* also. way to hot out......  :bigshades: I think the 11" converter is realy killing the car..... Im getting a custom one built....
« Last Edit: July 20, 2008 - 12:24:04 PM by StRoKer »
« Reply #20 on: July 20, 2008 - 12:24:18 PM »
(I got a built 727 with a transbrake in it and an 8 inch if you wanna try it out. It would change your 60ft a bunch and you could still run it on the street since you run a cooler and it has a deep pan on it. Come on down, grab this dana and try out this tranny. I did a thousand miles in one day, you can too.
