not sure why everyone wnats to dump the T bars so badly , any coil over suspension puts the stress onto the body where it is not designed to take the load so as long as you do not mind installing a roll cage or adding a triangular brace over the engine like a mustang to both shock towers & the firewall no prob .the only decent system is the Alter-K-tion
there is no reason why you cannot have a lower stance & better handling with the stock parts though , re-inforce the K frame lower control arms , add tubular uppers ofr more caster adjustment , use a larger diameter T bar & repalce the Ball Joints with Moog & use C body tierod ends & sleeves , replace all the bushings with either new rubber or stiffer poly & add better wheels & tires , add the frim feel strg box for better steering , add larger F & R sway bars , premium shocks & keep the leaf springs at a flat arc & you can get very close to 1 g cornering
there is also the CAP Tubular K frame that uses T bars & stronger lower control arms
