Author Topic: Ignition Locks  (Read 554 times)
Offline MrMopar440
Ignition Locks
« on: July 17, 2008 - 04:55:07 AM »
I am getting ready to order a new ignition lock for my steering column. I found two at Autozone (no shipping charges to APO addresses  :woohoo: ). One is from Lockworks: #LC14440 @$16.99. The other is from Locksmart: #LS48820 @$16.99 but also comes with two door locks (nice to have them all the same). Has anyone used either? How do they look/fit? The ignition lock is for a 1970 column and the doors on on a 1973. From what I can find, only the ignition lock was different so I should be good. Thanks for the help.
Re: Ignition Locks
« Reply #1 on: July 17, 2008 - 05:09:50 AM »
no problem , I have used both makes of locks in the past
Offline MrMopar440
Re: Ignition Locks
« Reply #2 on: July 17, 2008 - 05:32:45 AM »
Thanks CP. I figured that you would know  :worshippy . Now if only Autozone would carry the fuel filter I need (HPGC1) than I would be able to get everything in one shot.
