Let me help a little. You will need to disconnect your steering linkage because it goes between the tubes of driver side hedder. When I installed mine, I had the engine out and put the hedder in first, then intalled the engine.
The mini starter will fit with this design because I am using it.
The main issue with this design is the clearance you have with the ground, or should I say lack there of.
If you run Edelbrock heads like I am doing, you have to remove the driver side hedder to get the #5 & #7 spark plugs out.
Good luck with the install.
