Author Topic: d rings  (Read 609 times)
Offline 70 340
d rings
« on: July 17, 2008 - 09:55:24 PM »
Is there anything negetive about using the d rings on accumulator piston?More maintenance sticking piston longevity.
street car basically stock 340 727 with transgo TF-2 kit.Thanks for advice.
Offline tactransman
Re: d rings
« Reply #1 on: July 18, 2008 - 08:42:26 AM »
If you use the "D" rings,you HAVE to scotch brite the bore in the case to make small lube grooves to hold fluid or the "D" rings will not last long. I don't "D" ring them unless I am going to block the piston solid.
Terry-tactransman
Union, Mo.
