Author Topic: a 440 6 pak Question  (Read 1084 times)
Offline lazerboat
  • whatz done is done
« on: July 17, 2008 - 10:52:29 PM »
did 440+6 ever come with ac looking to put ac :feedback: :feedback: on my 71 runner with air grabber but dont know if it will fit
Re: a 440 6 pak Question
« Reply #1 on: July 18, 2008 - 12:51:09 AM »
the new kits using the Sanden compresser will fit with just a small amount of trimming on the air cleaner base , the original style 2v pump will not fit
Offline ksierens
    • 70 Challenger Resurrection
« Reply #2 on: July 18, 2008 - 07:53:24 AM »
I have also seen kits that will allow you to "under mount" the compressor, though you will have to remove the fuel pump and go with an electric one.
Kurt - SE Michigan
Offline Robb
« Reply #3 on: July 18, 2008 - 10:17:03 PM »
if you run the lines to the Sanden compressor right, you shouldnt have to trim the base.
I have the AC/and the sixpack in my car.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline lazerboat
« Reply #4 on: July 19, 2008 - 11:25:11 AM »
thanks for all the input , will the sanden compresser work with the stock plumbing, and brackets  ,and do you guys know if small and big block brackets are he same . so ac was not an option on 6 pac or air grabber /shaker cars I never really paid much atension ,
« Reply #5 on: July 19, 2008 - 12:05:14 PM »
correct , no multi carb / shaker / air grabber cars had AC
Offline Robb
« Reply #6 on: July 20, 2008 - 04:08:30 AM »
small and big block brackets are not the same,       in fact 383 and 440 brackets are not the same.
sanden will not work with stock brackets.    you need to check out bouchillon.com
you can have your original hoses that attach to the compressor re-done so that they will match up to the compressor.
youll need a cycle switch too with the sanden.
do a search on this site and youll find a couple of good threads on this topic if youre really serious.      search "sanden"
