Author Topic: Hesitation  (Read 1212 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Hesitation
« on: July 18, 2008 - 11:03:20 AM »
My 340 with eddy RPM airgap and RPM camshaft always hesitates when I give gas on low RPM's, higher RPm's is now problem.
Any bright ideas?  :feedback: Carb is a 600 cfm, not to forget it takes 1 battery to start it every time the cars has been standing for a while although it's
a warm garage.  :clueless:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: Hesitation
« Reply #1 on: July 18, 2008 - 11:19:36 AM »
I assume you are running an Eddy carb , the flaot level is set too low
Re: Hesitation
« Reply #2 on: July 18, 2008 - 12:36:37 PM »
OK, good for booth problems? :thumbsup:
Offline RDF
  • The pain that greets me is the stick that beats me
Re: Hesitation
« Reply #3 on: July 18, 2008 - 01:10:11 PM »
I have the same problem with my 360, 600 Eddie carb....at low rpm's, it seems to choke on itself, almost as if too much gas is getting to the carb, but once through that it's fine after.  I replaced wires, coil, plugs, fuel tank sending unit and more but I've always had a feeling the carb isn't adjusted correctly.  My problem is I don't know anyone around here that can adjust them...You'd think living in Orlando that someone would be able to, but all the big shops and some small "mom & pop" shops that I've gone to say they won't touch it.  :banghead:
I don't know what I'm doing with carbs, otherwise I would try something myself.  CP,  Is it hard to adjust the float level? :dunno:
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
Re: Hesitation
« Reply #4 on: July 18, 2008 - 02:36:06 PM »
Goody is kinda close to Orlando I think and has masterd that eddy bastur... I mean type of carb you have
Offline GoodysGotaCuda
Re: Hesitation
« Reply #5 on: July 18, 2008 - 10:34:48 PM »
we could pop the top off your carb bob and poke around while you are here. Just see if anything is gunked up, float hanging or something
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: Hesitation
« Reply #6 on: July 19, 2008 - 02:34:22 AM »
Eddys typically have the floats set too low & this limits the filling of the accerator pump well which makes the car hard to start & stuble as the throttle is opened
Offline RDF
Re: Hesitation
« Reply #7 on: July 19, 2008 - 07:57:59 AM »
That'd be good....just to see if there's anything real noticable or not.
Bob
1973 'Cuda
My build:
Offline 71chally416
    • The Streetwalker
Re: Hesitation
« Reply #8 on: July 19, 2008 - 04:46:40 PM »
You can re-use the gasket many times. Just don't break it taking it off.
