Author Topic: Lifter preload  (Read 547 times)
Offline 71chmark
Lifter preload
« on: July 19, 2008 - 12:48:01 PM »
What preloading the lifter mean?
What should I do when installing new lifters?
I may be schizophrenic,
Offline 71chally416
    • The Streetwalker
Re: Lifter preload
« Reply #1 on: July 19, 2008 - 01:45:47 PM »
Zero lash + 1/8th turn is optimum for a hydraulic cam. If you don't have adjustable rockers all you can do is shim the shafts if the lifters are preloaded too much. Of course if you have a bad valve job and the valves heights aren't the same you're screwed. You can buy rocker shaft shims from Mancini.
