Author Topic: 74 360 engine  (Read 2461 times)
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
74 360 engine
« on: July 19, 2008 - 04:35:39 PM »
I'm trying to finish cutting up this 74 charger so I can have my driveway back.What do you think the 360&904 are worth I'm keeping the fan,starter and alt.It turns over but I have never heard it run so I would think it needs rebuilding.I realy don't want to scrap it with the rusty shell but I have no room for it here.Also where is the numbers on the block I need to check to make sure it's a 360. Thanks Chuck
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline lazerboat
  • whatz done is done
Re: 74 360 engine
« Reply #1 on: July 19, 2008 - 05:52:59 PM »
hey I think you can tell by exhust manifolds , ill trade you for my  318  let me know  :nono:
Offline ElDoradoCuda
Re: 74 360 engine
« Reply #2 on: July 19, 2008 - 07:11:22 PM »
Where are you located?
Offline CHUCKS71
Re: 74 360 engine
« Reply #3 on: July 19, 2008 - 07:15:15 PM »
Wonder Lake IL
Re: 74 360 engine
« Reply #4 on: July 19, 2008 - 10:28:28 PM »
If no body grabs up on this, there is a member needing a 360 for his project he is building. He is over in Iraq. He wants me to build him a 360 stroker for his M46 car. Let me know something...thanks
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: 74 360 engine
« Reply #5 on: July 19, 2008 - 11:30:42 PM »
  There should be some numbers stamped on the drivers upper front of the block.  If there are none in that location there is a vin on the passengers oil pan rail. There should also be some raised cast numbers on the drivers side behind the exhaust manifold.
  I purchased a 72 318 running great for 250 bucks.  I would think the 74 360 would be worth close to that range since you don't know if it is running or not.  That's my two cents anyway.
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: 74 360 engine
« Reply #6 on: July 20, 2008 - 02:38:30 AM »
I saw a 360 (5.9 Mag) on racing junk for $300.00 that needed "freshened up".  Hope this helps.
Don
« Last Edit: July 20, 2008 - 02:40:19 AM by The Cuda Guy »
Member Since January 14, 2002
Offline go-fish
Re: 74 360 engine
« Reply #7 on: July 20, 2008 - 05:00:43 AM »
These 360's (71-74) are excellent blocks. They are much stronger than later 360's. They are also a bit more sought after by drag racers because of the thicker cyl. walls and main webbing.
These are good blocks to turn into big bore strokers.
*3418496*   360   1971-74   (LA-series)
Al, I have an old truck, 1971, that has one of these. If you're ever in the neighborhood we can throw it in the back of yer truck. It has something like 60,000 miles but it needs an overhaul (4" crank :cooldancing: ).
Offline go-fish
Re: 74 360 engine
« Reply #8 on: July 20, 2008 - 05:02:35 AM »
BTW, he was supposed to come get this truck from me but he was leaving soon and couldn't make it happen. Didn't think he was wanting the engine for his M46 though.
Offline torredcuda
  • Epping NH joined 11/23/03
Re: 74 360 engine
« Reply #9 on: July 20, 2008 - 07:31:54 AM »
I can get 360`s from $100-300,being an early one I would go $250-300.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline CHUCKS71
Re: 74 360 engine
« Reply #10 on: July 20, 2008 - 07:40:43 AM »
Thanks for everyones input! I know I have to pull it out But I really don't want to have it laying around here.
Offline go-fish
Re: 74 360 engine
« Reply #11 on: July 20, 2008 - 08:03:36 AM »
Get a 50 gallon drom and put it in there with used motor oil.  :icon16:
Offline wally426ci
    • maryland mopars
Re: 74 360 engine
« Reply #12 on: July 20, 2008 - 09:32:41 AM »
Go-Fish, what are the odds that the '71 Truck needs a new home?? how bad is it?  :bigshades:
Chuck, make sure you keep every last d@mn little nut and bolt for your car. if yours is AC, keep that blower motor too.  :bigsmile:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: 74 360 engine
« Reply #13 on: July 20, 2008 - 09:36:44 AM »
The engine is for member 426hemi, I will figure out a way to get this from you some how. Or will find one eventually. I have to go get a flatbed and wrecker his car up to my place. He is having problems and asked if I could go get it and store it for him.
  • Pearl Harbor, HI
    • C-C.com
Re: 74 360 engine
« Reply #14 on: July 20, 2008 - 10:30:28 AM »
I know Gordon mentioned he wanted a 360 for his cuda!  Good looking out Alan!
Don
