Author Topic: Need a Master Cylinder rebuild. Does anybody know theses guys?  (Read 5234 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
I have an orginal 70 Challenger Master Cylinder that needs to be rebuilt. Does anybody know theses guys?
http://www.applehydraulics.com/brakes.htm
http://www.brakeplace.com/
« Last Edit: July 24, 2008 - 08:27:28 PM by Tropicalcats »
SOLD
Offline kameront2003
Re: Need a Master Cylinder rebuild. Does anybody know theses guys?
« Reply #1 on: July 28, 2008 - 03:57:42 PM »
I dont know them but try these guys!  Master cylinders can also be professionally rebuilt at places like Brake and Equipment Warehouse in Minneapolis and White Post Restorations in Virginia.
« Reply #2 on: July 28, 2008 - 06:01:49 PM »
Thanks for the reply
http://www.brakeplace.com/ is Brake and Equipment Warehouse in Minneapolis and they do seam to know the master 2229171.
 Hers an interesting part I am told by some that the rebuild kit for this was not availablt but the foks at Brake and Equipment Warehouse tell me it is. Sometimes I just don't know what to believe.
SOLD
« Reply #3 on: July 28, 2008 - 06:03:40 PM »
Does your MC need to be sleeved due to excessive pitting ? ....... otherwise rebuild it yourself  nothing to it
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=UP&PartNumber=620&Description=Brake+Master+Cylinder+Kit
« Reply #4 on: July 29, 2008 - 01:13:24 AM »
virtually any part is available if you know where to dig for it , the people who tell you it is not are just looking at their limited suppliers
Offline JH27N0B
« Reply #5 on: August 01, 2008 - 11:17:53 PM »
I wouldn't advise using a 1-1/8" kit to rebuild a master cylinder with a 1" bore! :o
The kits for these have not been available for decades.  However if the pistons are still in good shape, one can take the seals out of another kit for a 1" master cylinder and use them to replace the seals on the old pistons.
Brake and Equipment warehouse was talking about making up pistons for these, in fact I made up some engineering drawings of the pistons and gave them to Brake and Equipment warehouse in spring of 2007.  I haven't talked to them since to see if they ever ended up making them.
Offline JH27N0B
« Reply #6 on: August 01, 2008 - 11:25:13 PM »
Here you go, with this drawing, some aluminum stock, and a good machining cell, you too can make up these rare pistons! The secondary piston is supposedly the same as one used on another master cylinder that has kits available, so make up a batch of primarys and you are the '9171 king!
« Reply #7 on: August 02, 2008 - 12:43:04 AM »
Here's a 1" bore kit they list for a 70 Challey with 4 wheel drum brakes
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=UP&PartNumber=474&Description=Brake+Master+Cylinder+Kit
They list 3 kits total, the 1st one I posted 1 1/8 bore front disk rear drums &
a kit for the Hemi car that is also 1 1/8 bore but a different part#
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=430&Keyword=Brake%20Master%20Cylinder%20Kit&KeywordCat=Brake+Master+Cylinder+Kit&VehCode=Y
Offline JH27N0B
« Reply #8 on: August 02, 2008 - 01:56:43 AM »
The one year only 1970 disc brake master cylinder for non-hemi E bodies has a casting number 2229171 and has a 1" bore.  The drum brake master cylinder is 1" bore also, however the pistons are not the same as the disc so the kit cannot be used for a disc brake master cylinder.  Some of the seals can be removed from the kit pistons and used on the disc brake pistons, but I don't think that kit has every seal needed to redo both disc brake pistons.
The 1-1/8" kit they list for a hemi will not work on the correct 2229191 casting number master cylinder found on '70-71 disc brake hemi cars.  The primary piston is too short. I know this first hand. I had to have some pistons made up several years ago to restore one of these master cylinders I had at the time.
I used to work for the company that made United brake parts, I know very well what there catalog lists and that there are many errors.
I don't believe any kit was ever manufactured by the aftermarket to service the 2229171 casting number master cylinder, even in the 70's.  If anyone did list it back then, it would have been an OEM Bendix kit purchased by an aftermarket company and sold in the aftermarket companies box.  Good luck finding one now!
« Last Edit: August 02, 2008 - 01:58:52 AM by JH27N0B »
« Reply #9 on: August 15, 2008 - 10:40:09 PM »
 Just an update for you. They did end up making some of the pistons from your drawings. it was a funny thing this guy name Rob from Brake and equipment warehouse and I had a conversation today and my master needs a new piston and he tells me about this guy that did drawings for them and thats how he can make up the new piston for my 2229171. Its a small world.
SOLD
Offline 71chally416
    • The Streetwalker
« Reply #10 on: August 15, 2008 - 10:50:41 PM »
I just went to the local Autozone and got a rebuilt one. They had to order it. Had Cardone on the box.
Offline JH27N0B
« Reply #11 on: August 16, 2008 - 12:26:22 PM »
Hope they work! ;D
I designed one for the 2229191 "hemi" MC at my old work and had a few made up and they seem to be working well, hopefully I know what I'm doing...... :eek4:
« Reply #12 on: August 16, 2008 - 02:42:47 PM »
Hope they work! ;D
 They had nothing but good things to say about you. My guess is you know what your doing. :2thumbs:
SOLD
