Author Topic: Water in the carb  (Read 805 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Water in the carb
« on: July 20, 2008 - 08:19:08 AM »
I got some water in the gastank and evidently some of it ended up in my carb. After emptying the system it's still doesn't run when loaded.
Can the carburator have been damaged by having some water in it for a week or two? I have been driving the car between emptying the tank
but since water is heavier then gasoline the water in the carb has propably been sitting. Will try open it and see if I find something.  :1zhelp:
//Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline Changin Gears
Re: Water in the carb
« Reply #1 on: July 20, 2008 - 08:25:16 AM »
Have you tried putting some "Dry Gas" or fuel line anti freeze in?  It absorbs the water.  I have to do this in my boat periodicly.
Offline BB73Challenger
« Reply #2 on: July 20, 2008 - 08:28:24 AM »
WOW could you have had enough water in it to do damage?
The first thing that comes to mind is possible rust/other contamination in either jets or needles?
What kind of carb are you using?
You may have a complete tear down, dipping and re-build needed if you are sure you car was fine till the carb had water in it.
Jeff from Cleveland, Ohio
« Reply #3 on: July 20, 2008 - 08:29:31 AM »
That's good too if you think you still have the "bad gas" in your system.
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #4 on: July 20, 2008 - 08:40:40 AM »
How does the fuel filter look?  :dunno:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline 71chally416
    • The Streetwalker
« Reply #5 on: July 20, 2008 - 08:51:31 AM »
They sell water injection systems for cars so I doubt that a little water is gonna hurt a motor.  :misbehaving:
« Reply #6 on: July 20, 2008 - 10:38:41 AM »
Opened the carb, it was full of ****. Propably missed something at reassembly because it's keep hangning at higher RPM's.
It's a new eddy 800 cfm, took my old 600 on and the car runs good again.
