Author Topic: 340valve noices  (Read 1106 times)
Offline tvacuda340
  • F1A procharger 422 small block
340valve noices
« on: July 20, 2008 - 04:40:52 PM »
hi
 340 la with  crane  hydr roller dur222/339  and   520 -568 lift  with 1,6 ration rocker arms
it hear like it is comming from the valve... when it closing  or? ??
Re: 340valve noices
« Reply #1 on: July 20, 2008 - 05:06:29 PM »
What kind of noises?  Did you make sure you had enough piston to valve clearance?
Offline tvacuda340
Re: 340valve noices
« Reply #2 on: July 20, 2008 - 05:36:49 PM »
yes
 it is not kocking sound .....its like tapping
 can it be the valve closing fast
Re: 340valve noices
« Reply #3 on: July 20, 2008 - 05:45:24 PM »
Do you have adjustable rocker arms on it?  Does it sound like it is in one location or all over the top end?
Offline tvacuda340
Re: 340valve noices
« Reply #4 on: July 20, 2008 - 05:53:03 PM »
i have adj arm on
it is all over
mayby it must sound like that
it is after i got magnaflow full exhust on (before flowmaster )
now i hear all noices
nivvy
Re: 340valve noices
« Reply #5 on: July 20, 2008 - 06:02:06 PM »
get a scope put in on the valve covers while the car is running youll pinpoint it down... maybe its somewhere else. i thought mine was coming from the valve cover and it turned out to be loose converter bolts...
Re: 340valve noices
« Reply #6 on: July 20, 2008 - 06:38:38 PM »
A tapping sound could be a leak between the heads and your exhaust manifolds, or headers.   :grinyes:
Offline JayBee
Re: 340valve noices
« Reply #7 on: July 20, 2008 - 06:46:02 PM »
I was going to mention that too. When I heard a tapping sound coming from mine I also thought it was the valve train, after re-tightening the exhaust mainifolds it went away.
John
1970 Barracuda convertible
2014 Toyota Avalon
Re: 340valve noices
« Reply #8 on: July 20, 2008 - 06:49:47 PM »
...So you've been down that road too?    :banghead:
Re: 340valve noices
« Reply #9 on: July 20, 2008 - 09:52:03 PM »
 :screwy:  Yesterday evening I had my radio turned down real low, so low I really couldnt tell it was on. But I thought I kept hearing a noise under the hood towards the back of the engine. It was my center speaker. I could hear the base a little bit :roflsmiley:  Got me tho
