Author Topic: Z Bar question  (Read 1771 times)
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
Z Bar question
« on: July 20, 2008 - 06:14:05 PM »
I have a Z-bar that came with my 833 and I was told it came from a 71-74 B-Body.Will this work on my 71 Challenger? How can you tell the difference from one Z-bar to the next.If this is the wrong one for me does anyone know if it is the right one for a 71 Roadrunner.Thanks Chuck
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline matt63
Re: Z Bar question
« Reply #1 on: July 20, 2008 - 08:45:29 PM »
Not sure on how many different types but IIRC there is a big and small block version for each body style.  I would check Brewer's website as they sell repro's for A, B and E bodies. http://www.brewersperformance.com/products.asp?id=105
Matt in Edmonton
'68 Valiant
Offline CHUCKS71
Re: Z Bar question
« Reply #2 on: July 20, 2008 - 09:09:37 PM »
On the Brewer's site it looks like the  1970-1971 E-body/1971-2 B-body big block applications with 10.5" bellhousing  use the same and the 1966-70 B-body big block, 1970-74 E-body & 1971-74 B-body small block use the other one.Does anyone have a measurement on a small block car and a big block car so I can see with one I have?
Re: Z Bar question
« Reply #3 on: July 21, 2008 - 02:16:38 AM »
it will interchange with the E body & looks correct , the small block & big block bar is about 1/2 " different in width but usually will work either way
Offline CHUCKS71
Re: Z Bar question
« Reply #4 on: July 21, 2008 - 04:58:24 AM »
 :woo: THANKS
Offline Sean
    • My Cuda Restore
Re: Z Bar question
« Reply #5 on: July 21, 2008 - 09:04:36 AM »
Newbie Question...
What is a Z-Bar?  I'm assuming that its what the clutch pedal connects to to engage/disengage the clutch - mounted to the firewall?
Thanks!
Sean
Offline NoMope Greg
Re: Z Bar question
« Reply #6 on: July 21, 2008 - 11:34:04 AM »
Newbie Question...
Thanks!
Sean
That's correct, although it's not mounted to the firewall, but to the driver's side framerail and the clutch lever.  Here's a photo.
« Last Edit: July 21, 2008 - 11:40:26 AM by Greg's HO R/T »
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline Sean
    • My Cuda Restore
Re: Z Bar question
« Reply #7 on: July 21, 2008 - 12:11:43 PM »
Greg,
Thank you Sir for the info and the pic!!!
 :cheers:
Sean
Offline hemiken
Re: Z Bar question
« Reply #8 on: July 21, 2008 - 01:58:51 PM »
Actually Chucks Z-bar is the kind of bar you can sit down and drink Coronas at apparently :poopoke: :smilielol: :roflsmiley: :rofl: :lol2: :lol: :grinyes: :bananasmi
Offline matt63
Re: Z Bar question
« Reply #9 on: July 21, 2008 - 04:47:17 PM »
Some call it a torque shaft instead of a z-bar ie Brewer's Performance
Matt in Edmonton
'68 Valiant
Offline CHUCKS71
Re: Z Bar question
« Reply #10 on: July 21, 2008 - 04:51:23 PM »
Thats right come on over I'm buying!  :cheers:
Offline Changin Gears
Re: Z Bar question
« Reply #11 on: July 21, 2008 - 04:55:18 PM »
Z-bar is a Chebby term, torque shaft is MoPar
Re: Z Bar question
« Reply #12 on: July 22, 2008 - 12:54:51 AM »
or belcrank
