Comp Cams Hydraulic-Roller Cam Shaft, #23-712-9 - $306.99 (on Jegs.com)
Hydraulic Lifters for above cam shaft #8921-16 - $587.99 (jegs)
Beehive Springs recommended for above shaft and lifters #26120-16 - $204.99
Aluminum Roller Rockers, 1.5 ratio #1071-KIT - $959.99 (non-alum. $505.99)
Adjustable 3-bolt Timing Set #3125KT - $204.99
Steel Retainers - $56
Valve Locks - $42 (!!)
Valve Guides - $23
Lash Caps (what the heck are those?) - $37
Push Rods - 7/16" "Semi Finished" (apparently I have to have them custom cut) $162.99
FIRST of all, how the hell is the Camshaft one of the CHEAPEST pieces of all this, second of all,
$2,131 for all the timing parts?!?!?!?!
*starting to reconsider a CRATE engine...*
$$$$Jeff
