Author Topic: 451 wedge parts  (Read 1063 times)
Offline common 27
451 wedge parts
« on: July 21, 2008 - 10:53:29 PM »
I have the parts to build a 451 wedge for sale.Included is a 400 block bored .035 and sized to new pistons with new cam bearings installed.
The strocker kit is 440 Source.Flat top pistons.forged crank and rods upgraded to I beams and 2000 ARP bolts.includes bearings and
rings.Kit has also been balanced. Edelbrock RPM aluminum heads,closed chamber,84 cc.with Arp head bolts, aluminum valve covers
ingraved 451 WEDGE, Hughes Racing rocker shafts,billet steel holddowns and Crane ductile iron rocker arms,1.5 ratio. Engle Cams Solid
lifter camshaft KV-1  546 lift,239 duration @ .050 .The following parts are Mopar Performance -solid lifters ,aluminum water housing and
heavy duty aluminum  6 blade water pump,and a  Electronic distributor with chrome box.Cloyes TRUE double roller timing set,High
volume oil pump by Mellings and harden pump shaft,a 7 qt. oil pan with long pickup. Intake is a Holley Street Dominator with a 1 1/2
spacer and a Holley 850 double pumper.Aluminum 14 inch air cleaner. Jegs Prostart'r starter,TCI break-a-way 11 inch converter ,727
transmission rebuilt by TAC and shift kit added. These parts are all new- never installed and are not the cheap  Chinese parts you can buy .
Included are a set of barely used Hedman headers  Used parts are the alternator and fan. Engine needs put together. To finish you'll need
the push rods,gasket set,freeze plugs,and misc. bolts for manifold.pan,timing cover, gas line, spark plugs and wires, pulleys and a balancer .
I'm sure  a few other parts will be needed also . I have more invested in this but would like $5000 for the whole pile of parts. Located in
southeast IOWA.  If interested email-  common 27
1970  Challenger Convertible   1968 Satellite Convertible
Offline 6pkattack
  • Newbie
Re: 451 wedge parts
« Reply #1 on: July 24, 2008 - 09:27:51 PM »
What is the reason for selling? i may be interested. Looking for a motor for my wifes grocery getter. :clueless:
Offline common 27
Re: 451 wedge parts
« Reply #2 on: July 26, 2008 - 12:13:39 AM »
  I didn't really want to let it out but I may of found the 72 Hemi Cuda!! Any way the parts for this were selected exactly for a grocery getter. Why put together a engine and then add a cheap water pump,or a cheap dampner.etc. the parts for this were picked to make a strong street engine that will live AND can be driven. Add the few parts needed and tear up the parking lot at your nearest grocery. You're biggest problem is wanting to pull it from your wifes car and stick it in yours    :roflsmiley:
Offline common 27
Re: 451 wedge parts
« Reply #3 on: August 05, 2008 - 09:56:01 PM »
  Any interest in the parts if I break them up?
Re: 451 wedge parts
« Reply #4 on: August 08, 2008 - 10:19:57 PM »
Tell me about your headman headers please, I may be interested in them if you go parting out
Offline common 27
Re: 451 wedge parts
« Reply #5 on: August 09, 2008 - 04:52:23 PM »
 They are the ones stroker had in his car before he went to 2 inch.I've decided not to break it up.If I can't sell together I'll just go ahead and build it. I had a really sweet deal on a car and needed to get some cash fast, but couldn't so now it is gone :crying:
