Author Topic: OK how about these heads?  (Read 2010 times)
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
Re: OK how about these heads?
« Reply #1 on: July 22, 2008 - 08:37:43 PM »
Is this my eye's playing tricks on me or is this not right?
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline 71chally416
    • The Streetwalker
« Reply #2 on: July 22, 2008 - 09:42:09 PM »
Bad valve job. Some of the seats are sunk into the head. Look at difference in the top angle cuts adjacent to the valves by the arrows. When you see a big top angle cut like that it's because the 45* seat the valve face rests on is sunk into the port and they needed a big top angle cut to narrow the seat. Either somebody was careless with the grinder or the head has had multiple valve jobs. It's usually the exhaust seats that are beat up from the heat, not the intake seats. I would avoid these heads if you want heads that flow at least as much air as they did when they were new.
« Last Edit: July 22, 2008 - 10:55:42 PM by 71chally416 »
nivvy
« Reply #3 on: July 22, 2008 - 09:48:28 PM »
shop around. you can find aluminum eddys for that price.. i sold a set of fully ported 906's with big valves for 850 shipped.....  :working:
Offline 71chally416
    • The Streetwalker
« Reply #4 on: July 23, 2008 - 01:05:19 AM »
Just for comparisons sake, here are a few pics of a small block T/A head I ported last year. This is what I would call "fully ported". That term (IMO) has to include reducing the valve guide boss to a minimal size, and not mearly minor pocket porting 1/4" down from the seat and bellmouthing the Intake face. Which heads do you think will flow more air? I already know. These heads flowed 30% more air than a iron stock W-2 I tested :smokin:
« Last Edit: July 23, 2008 - 01:09:24 AM by 71chally416 »
Offline 71chmark
« Reply #5 on: July 23, 2008 - 06:19:01 PM »
Won't aluminum heads on my already low compression engine make it worse?
I may be schizophrenic,
« Reply #6 on: July 23, 2008 - 07:09:53 PM »
Aluminum heads will allow you to go with higher compression and still use pump(93 octane) gas.
Offline 71chmark
« Reply #7 on: July 23, 2008 - 09:52:48 PM »
how do I get higher compression? I have to change the bottom? Don't want to pull the motor.
« Reply #8 on: July 23, 2008 - 09:59:45 PM »
Shave the heads to 55cc and zero deck :bigsmile:  no don't  114 octane
nivvy
« Reply #9 on: July 23, 2008 - 10:41:47 PM »
thinner head gaskets .....
