Author Topic: Yellow wire with light/blue cap  (Read 4752 times)
Offline roy282
« on: July 23, 2008 - 02:01:36 PM »
Would someone be so kind I telling me where this light is placed?  I know it's not for the ashtray .Thanks for your time!! Rob
« Last Edit: July 23, 2008 - 02:03:34 PM by roy282 »
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Yellow wire with light/blue cap
« Reply #1 on: July 23, 2008 - 06:16:19 PM »
shifter light in console.
Offline JayBee
« Reply #2 on: July 23, 2008 - 07:19:09 PM »
Looks more like the switch panel bulb to me, my console light has an orange wire.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #3 on: July 23, 2008 - 07:27:59 PM »
either title lamp for ign. switch or over the headlight switch- used via the time delay relay
Offline cudaguy71
« Reply #4 on: July 23, 2008 - 07:50:57 PM »
 :iagree:  Used to illuminate the switch panel.
« Last Edit: July 23, 2008 - 08:12:55 PM by cudaguy71 »
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
2003 Dodge Dakota Sport
1979 Plymouth Arrow
« Reply #5 on: July 23, 2008 - 07:55:58 PM »
The switch panel bulb wire is like 6 inches long with a connector
Offline roy282
« Reply #6 on: July 23, 2008 - 08:50:24 PM »
Thanks CC members I'm pretty sure now that is for the switch but just to be sure,is the title lamp the one in the steering column and do both rallye and non rallye have the light behind the switches and are they in the same location and do they operate the same?? Thanks for your ebody knowledge!! Greatly appreciated!!  :cheers: Rob
Offline roy282
« Reply #7 on: July 25, 2008 - 05:42:24 PM »
Ok members could someone let me know if both lights are supposed to be there on a rallye dash gran coupe or se challenger.the lights that I'm referring to the one at the far end of the light bar and the one that shines through the bottom of the switch panel? See pictures and Thanks for your time! Rob
Offline cudaguy71
« Reply #8 on: July 25, 2008 - 05:44:54 PM »
I have both of them on my Rally Dash...
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
1979 Plymouth Arrow
Offline hemiken
« Reply #9 on: July 25, 2008 - 05:47:59 PM »
The top light is for the switch panel and the lower light mounted in behind the switch panel shines through the hole to light up the A/C or heater panel :2thumbs:
Offline roy282
« Reply #10 on: July 25, 2008 - 06:04:08 PM »
Ok one more question the one on the switches connects to where?
« Reply #11 on: July 25, 2008 - 10:23:50 PM »
I think its a brown wire on the harness that is really close to it when you pull the panel. It is hangin out og the harness about 6" or so. it would be close to where the vin tag is , or where if you had a 3 speaker dash and pulled the left speaker out, the wire would be right there
Offline roy282
« Reply #12 on: July 26, 2008 - 09:08:50 PM »
Thanks Moparal and member's I'll take a look in that area to see what's there! 71 DEPUTY or anybody could you tell me what the title lamp for ign. switch is, pretty sure that it is the one that's in the column? is that right? and the over the headlight switch- used via the time delay relay that's the one shown in the pic with the light bar which end's up connecting to the relay? How exactly does the relay work and it's purpose?Thanks Rob
« Last Edit: July 26, 2008 - 09:27:24 PM by roy282 »
Offline ShelbyDogg
« Reply #13 on: July 27, 2008 - 11:05:55 AM »
The little lamp for the ignition switch was only available with the light group. If you didn't have the group, a little plastic rounded cover was placed in the round bottom of the emergency flasher switch hole. It lights up the key slot on the same timer as the other light.
Offline 71 DEPUTY
    • Cardomain
« Reply #14 on: July 29, 2008 - 07:34:32 PM »
check lower right side diagram!
