Author Topic: Need some Help Electronic ignition  (Read 1285 times)
Offline cdecristo
    • My Challenger Website
« on: July 23, 2008 - 03:24:01 PM »
My 70 Challenger is not keeping the battery charged. The alternator does not seem to be working. I have some questions that might be the problem.
Are there 2 kinds of ballast resistors ? one for electronic ignition , one for points?
Are there two kinds of ignition coils? one for elctronic ignition , one for points?
Could this be the problem?
thanks
1970 Dodge Challenger R/T SE
Re: Need some Help Electronic ignition
« Reply #1 on: July 23, 2008 - 03:43:30 PM »
I know that they list different coils but these ignition parts would have nothing to do with the charging system........can you charge your battery from another source?
Offline cdecristo
« Reply #2 on: July 23, 2008 - 03:49:31 PM »
yes I can charge my battery from another source .
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #3 on: July 23, 2008 - 06:15:27 PM »
thanks
« Reply #4 on: July 23, 2008 - 07:23:49 PM »
Tech writeup on diagnosing....I would just take the alternator to a parts house that can bench test, if it shows bad pull the brushes & see if they are shot, if so replace them..if it tests good all that's left is the voltage regulator or bad wires.
http://www.moparaction.com/Tech/questions/ELECTIFYING.html
