Any idea where I can find some of these relays??
Author Topic: Any idea where I can find some of these relays??  (Read 3222 times)
Offline purplehrtchallenger
« on: July 24, 2008 - 12:21:19 AM »
Hey guys,
I am finishing up the wiring on my '70 challenger....looking at the wires under the dash and the schematic, and looks like i need a few relays. :bricks1:
Any idea where I can find the following switches/relays:
light buzzer diode?
headlight delay relay?
rear defogger switch/relay (attached below dash)?
road lamp relay
thanks a million!!   :cheers:
PHC   :worshippy
Offline Red R/T
Re: Any idea where I can find some of these relays??
« Reply #1 on: July 24, 2008 - 09:55:39 AM »
 :popcorn: :popcorn:
1970 Challenger U code R/T SE
Offline roy282
« Reply #2 on: July 28, 2008 - 04:56:51 PM »
I picked up a time delay relay from NAPA part # AR613 once I plugged it in, my door ajar overhead counsel  light worked!! This is the relay right under the steering column with the three prongs  :woohoo: :jumping: :cooldancing: Rob
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
Offline wally426ci
    • maryland mopars
« Reply #3 on: July 28, 2008 - 04:57:58 PM »
 :popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline RaptorF229
  • A work in Progress
« Reply #4 on: July 28, 2008 - 05:00:00 PM »
Good to know on this one.
Offline matt63
« Reply #5 on: August 12, 2008 - 06:23:01 PM »
Some relays are available via auto parts stores still.  I usually check on rockauto.com to see if they are listed before checking around at my local auto wholesaler.
Matt in Edmonton
'68 Valiant
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #6 on: August 12, 2008 - 09:47:27 PM »
Go Fast & Have Fun...
Offline FY1Cuda
« Reply #7 on: August 13, 2008 - 11:27:54 AM »
On a Challenger a couple of years ago I got the the light buzzer working by just getting a regular old diode from Radio Shack and soldering on some spade connectors on each end to plug it in.  I picked the one that could take the most power. As you probably know, diodes only work in one direction, so you have to test to see which direction to plug it in.
