Author Topic: Rear axle help with seal install direction [ or ]  (Read 1465 times)
Offline MyMopar
« on: July 24, 2008 - 12:51:06 PM »
I need some help.  I'm not sure if the seals in teh axle are in the right way so while I'm getting new bearings on teh axle shafts I might as well make sure everything else is right.
The service manual really doesn't show a good pic of the seal installed and doesn't reference which way it goes in.
So anyone got a pic?  Right now the seal looks like it is installed like this ]
Is that right or should it be installed like this [
This is the inner axle seal just after the bearing assembly on the axle shaft.
Also the service manual says to run SAE80 and add the suregrip additive.  I don't have a straight 80 at the local auto store, so should I run the SAE90?
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Re: Rear axle help with seal install direction [ or ]
« Reply #1 on: July 25, 2008 - 02:56:10 AM »
the seals should look like this [           ]
 use 80-90 gear oil
Offline MyMopar
« Reply #2 on: July 25, 2008 - 11:01:00 AM »
Thanks, that is what I thought but the driver side was one way and the passenger side another, it looked like
]====O====]
Glad I went the extra step to replace the seals and gaskets when doing the gear swap.  I can't believe with all the problems the rear still worked in the car.
Offline BIGSHCLUNK
« Reply #3 on: July 25, 2008 - 11:33:14 AM »
Neil, great description! [         ]    :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
