Author Topic: Power window problems  (Read 1066 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
« on: July 24, 2008 - 03:04:56 PM »
My rear quarterwindow switches doesn't work, the one in the main frontpanel and the one at the rear window it self.
I have changed switches but doesn't get the window to moove up or down, any suggestions? Has recently worked.
How can I test if the motor is OK?
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: Power window problems
« Reply #1 on: July 25, 2008 - 02:48:31 AM »
hook 12v power to 1 connection & ground to the other at the plug on the wiper motor  , one way the window goes , the other it goes down
« Reply #2 on: July 25, 2008 - 02:41:06 PM »
Can it be that the frontpanel is the master and have to work before the local switches will work? When I try the switch at the rear window
I see on the ampmeter that I have power there and the motor works.
Offline ShelbyDogg
« Reply #3 on: July 27, 2008 - 11:09:02 AM »
Yes, all your power window wires have to go through the main driver's door switches first, then to each individual window. BOTH wires for each window, not just a hot wire.
