Author Topic: Front suspension "Clunk" or "Popping"  (Read 1809 times)
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« on: July 25, 2008 - 04:01:53 PM »
At least, I'm 90% sure it's in the front suspension....   :clueless:
My set-up:
I completely rebuilt the front end about 4 years ago.  I haven't driven it until recently, as there was no engine in it. New Polygraphite bushings, and new tie rods and ball joints.  I replaced the K-frame, the original one was worn horribly at one of the front strut rod holes, along with a replacement strut rod.  I added a huge-ass Hellwig swaybar while I was at it.  Original power steering.
Symptom:
Sometimes when backing out of my driveway, or after backing up then moving forward, I hear a "pop" or "clunk".  Everything seems tight when I checked it, but I haven't used a pry bar yet, but it kinda has me confused.  Seems like a lower control arm issue possibly, but all the bushings are new.
Where should start checking first?  How would you go about looking for this?
I want to 100% dial in the front end on this thing!   :swear:
« Last Edit: July 25, 2008 - 04:05:40 PM by RabidScott »
1970 Dodge Challenger
13.9 @ 101 with stock internally 440, OD 4 speed, 3.23 LSD
WaywardGarage.com
Offline FJ5_440
  • Wisconsin
Re: Front suspension "Clunk" or "Popping"
« Reply #1 on: July 26, 2008 - 12:50:35 AM »
Are you sure that it isn't a U joint?
** Shane **
Offline NoMope Greg
« Reply #2 on: July 26, 2008 - 01:42:01 AM »
My first thought as well.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline wally426ci
    • maryland mopars
« Reply #3 on: July 26, 2008 - 08:43:19 AM »
I have Poly bushings in mine, no clunk, but i can tell the difference from rubber. Im going rubber in the next car... I would say look at the U joint first, you sure its not in the rear??
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #4 on: July 26, 2008 - 09:11:26 AM »
Lower control arm Pivot nut nut tight enough?
Front strut nut not tight enough .
Trans mount broken
Bad engine mount
Bad driveshaft ujoint
Loose upper control arm ecentric bolts
Things to go over
Offline BB73Challenger
« Reply #5 on: July 26, 2008 - 10:51:35 AM »
Not to hi-jack this thread, but why rubber next time Wally?
Jeff from Cleveland, Ohio
Offline GoodysGotaCuda
« Reply #6 on: July 26, 2008 - 10:53:10 AM »
I'd guess strut rod bushings. My passenger side strut rod pops like that. If i roll out of the backyard and stop decent, i'll get a "pop" out of that side. Didn't know what it was for awhile and it hit me that the control arm is moving just a hair and the strut rod isn't keeping it in place. I'll get to it someday!
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline wally426ci
    • maryland mopars
« Reply #7 on: July 26, 2008 - 11:45:52 AM »
well, 73, I just think its a stiff ride that isnt completely necessary. I think I get a little extra vibration through the ecar b/c of it....  :blah: I just figure I'll do rubber in the dart and see what the difference is....
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #8 on: July 27, 2008 - 09:18:59 AM »
Thanks  :2thumbs:
Offline basement
« Reply #9 on: July 28, 2008 - 09:50:58 AM »
I had a strange issue like that. The geometry of the suspension does weird things in different situations, turned out being a bolt on the inner tie-rod  rubbing across the collector of the drivers side header, another reason I don't like headers.
Offline dwbiggs
« Reply #10 on: July 28, 2008 - 12:07:27 PM »
I had a noise coming from my front end when I put it all back together and it ended up being the strut rod not being tightened enough.
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« Reply #11 on: July 28, 2008 - 02:12:23 PM »
Doh!!  I didn't even think to check the U-joints!  The only thing that's not brand new on the list!  :sleeping:
Thanks for the list of stuff to check, I'll get under the car tonight, see if I can't find anything.   :working:
WaywardGarage.com
