Author Topic: 4 Speeds  (Read 2259 times)
Offline gichy
4 Speeds
« on: March 30, 2004 - 12:48:40 PM »
I'm a little bit confused! The 833 is a 4 speed manual and also the 833 OD is a 4 speed manual or is their a 5th gear  for the Over drive????? How does this work??
Also I have a 3 speed manual trans bolted on a 318cid will my bell housing/ z-bar/ clutch fork work or do I need to replace them?
Thanks for your help!
1974 Barracuda, 340cid, 4 speed OD !!
Offline Pistol Gripper
Re:4 Speeds
« Reply #1 on: March 30, 2004 - 01:13:48 PM »
As for the 4 speeds, the OD is basically an 833 with 4th gear being 1:1 and 3rd being a .73 overdrive.  The 3rd - 4th gear lever on the tranny is inverted so that you shift  1 - 2 - 4 - 3.  This means that in OD you are not going straight through the tranny, they had to beef them up a bit to offset it.
P.G.
O ne
B ig
A $$
M istake
A merica
Offline gichy
Re:4 Speeds
« Reply #2 on: March 31, 2004 - 07:34:07 AM »
PG Thanks for your reply!
Do you know if my 3 speed std bellhousing will work with the 4 speeds?
Re:4 Speeds
« Reply #3 on: March 31, 2004 - 09:18:42 AM »
The three speed and four speeds had a different mounting pattern, see this article:
http://www.moparmusclemagazine.com/techarticles/40618/
This one has a good rundown on the four speed trannys:
http://www.autohobbydigest.com/a-4spd.html
Hope this helps,
P.G.
O ne
B ig
A $$
M istake
A merica
Offline gichy
Re:4 Speeds
« Reply #4 on: March 31, 2004 - 10:01:14 AM »
Thanks for those web sites
That's was a great help.
Offline gichy
Re:4 Speeds
« Reply #5 on: April 05, 2004 - 11:02:04 AM »
Just picked up a 833 OD 23 spline from a 87 dodge truck for 100 bucks and thats canadian dollars   ha ha.
My question is, where's a good place to buy a 4 speed shifter and  linkages? and also does the regular 4 speed shifter fit the OD unit?
My input bearing retainer is 5.125" but my bell housing is around 4.3", do I have to mill the bell housing or the bearing retainer? or can I do both, it looks like if I drill the bell housing to 5.125" it will interfere with the fork attach.
My current bell housing is off a 3 Speed manual if that helps.
Thanks for the help
Re:4 Speeds
« Reply #6 on: April 05, 2004 - 11:24:15 AM »
I f you got the shifter with the tranny all you need is the shift rods , Brewers has thm available , you can also use a Hurst Comp + shifter , you will need a shifter mounting plate though Brewers has them too
 For the bel housing you need to either get an OD bel for the small block witha 5.125 hole or you can machine the front retainer down to 4.80 & possibly machine the bel up to 4.80 as well
Offline gichy
Re:4 Speeds
« Reply #7 on: April 05, 2004 - 11:38:03 AM »
Chryco
I did not get the shifter with the tranny. Will the mounting plate for the 4 speed shifter be the same as the 3 speed shifter. Does Brewers have a web site?
The Hurst shifter, is it for a OD uint or a regular 4 speed?
Re:4 Speeds
« Reply #8 on: April 05, 2004 - 11:41:53 AM »
Brewers doesn`t have a web site , phone is 937-698-4259
I`m not sure if the 3 spd plate is the same , it may be < the shifters are interchangable from 4spd to 4spd OD
