Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Alternator/Tac-- linked?
« previous
next »
Print
Pages: [
1
Author
Topic: Alternator/Tac-- linked? (Read 717 times)
DAYLEY/CHALLENGER
Resident
Still My Inspiration..1971, Rockingham, Nc
on:
July 27, 2008 - 08:44:44 AM »
Got a good one for you guys. While checking spark plugs the other day, I accidently pulled one of the wires off the back of the alternator. Didn't know it until I was in town Friday at dusk and the lights didn't work so well. I had driven the car during the day and noticed the tac was working as it should. Reading about 2700 at 55mph, (it had been jumping all over the place and even during turn signals). When I turned the lights on I then really noticed the discharge needle was way to the left.....So I got home asap and parked her. Went over the wiring and discovered the unhooked wire. Hooked the wire back up and now it is really charging but...........the tac is again all over the place. Any thoughts???
Logged
Dave or David
sleepychallenger
Guest
Re: Alternator/Tac-- linked?
Reply #1 on:
July 27, 2008 - 08:54:54 AM »
Logged
ShelbyDogg
Sr. Resident
Reply #2 on:
July 27, 2008 - 10:03:39 AM »
Now that you narrowed it down a little, try a different Alternator and/or voltage regulator to see if the problem goes away. Make sure that you have a good ground on the regulator. Run a ground wire like Chrysler did right to it if you have to.
Logged
GoodysGotaCuda
Sr. Resident
Reply #3 on:
July 27, 2008 - 10:05:31 AM »
Make sure it has a solid connection at the coil negative, may have bumped it messing with the wires.
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
July 27, 2008 - 12:51:24 PM »
the regulator is causing voltage spikes which affect the tach , there is a close limit regulator available from Mopar Performance which may help
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
