Author Topic: A833 parts list  (Read 24867 times)
sleepychallenger
A833 parts list
« on: July 27, 2008 - 10:13:03 AM »
update made 13 Aug 08 0339Z  :bigsmile:
Ok all, not sure if this is the right place or not. I am getting all the parts ready for my 833 swap when i get home. I would like to get a good list of where i am and where i need to be. below is a list of what i have. please respond with what else i need and i will add it to my list.
Transmission
Clutch kit
clutch bolts
Pedals
CLUTCH PEDAL STUD BRACKET
pedal -> zbar rod
z-bar
11" flywheel
clutch fork
ball stud bracket and ball studs
two shifter rods (Alan knows which ones)
clutch adjuster kit from brewers
shifter
shift handle and grips
I think that is it, please help me out. It would be much appreciated....please  :feedback: :feedback: :feedback:  :bigsmile: :bigsmile:
I'll start
11" bellhousing
shift grips lense
shifter mount plate
flywheel bolts
pilot bearing
shifter boot
reverse bar
shift rods
Clutch switch start wire harness
correct speedo gear
hardware
new rear tailshaft seal
shifter mounting pad
« Last Edit: August 12, 2008 - 11:36:00 PM by sleepychallenger »
Offline Changin Gears
Re: A833 parts list
« Reply #1 on: July 27, 2008 - 11:01:35 AM »
I like using a 10.5" bellhousing with scalloped pressure plate that allows you to use the 11" clutch.  This not only reduces rotating mass (10.5" vs 11") but reduces overall weight also with the aluminum bellhousing,
You will also need flywheel bolts and a pilot bearing (the Dakota needle bearing version is great).
« Last Edit: July 27, 2008 - 11:03:12 AM by Changin Gears »
sleepychallenger
Re: A833 parts list
« Reply #2 on: July 27, 2008 - 11:18:34 AM »
i already have the 11" flywheel and clutch so that is the bh that i have to get. thanks for the input and especially for leading me on to a great pilot bearing. cant forget those bolts, i would be rather pi$$ed if i got in there, got everything ready, and didnt have the bolts.
Re: A833 parts list
« Reply #3 on: July 27, 2008 - 12:55:45 PM »
sleepychallenger
Re: A833 parts list
« Reply #4 on: July 27, 2008 - 01:07:17 PM »
thanks, what is Transmission slip yolk
Re: A833 parts list
« Reply #5 on: July 27, 2008 - 01:26:28 PM »
The front of the driveshaft that 'slips' into the rear of the trans.
If you are replacing a 727 you are all set.  The 833 and 727 are the same length and use the same slip joint.
Re: A833 parts list
« Reply #6 on: July 27, 2008 - 02:05:46 PM »
Drew, the new clutch set up I gave you is the scalloped set up.  10.95
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: A833 parts list
« Reply #7 on: July 27, 2008 - 02:51:00 PM »
Drew thanks for compileing this list!
Don
Member Since January 14, 2002
sleepychallenger
Re: A833 parts list
« Reply #8 on: July 28, 2008 - 04:02:02 AM »
i am replacing a 727 so i am good, right?
what does that mean?? Did i get the wrong flywheel??
Re: A833 parts list
« Reply #9 on: July 28, 2008 - 09:34:49 AM »
no you have the right flywheel , you just need a 10.95" clutch setup to work with the 130 tooth flywheel ,Brwers has new bellhousings for $300 for this system, the larger 143 tooth uses a cast bellhousing & 11" clutch & is harder to get parts for
sleepychallenger
Re: A833 parts list
« Reply #10 on: July 28, 2008 - 09:41:39 AM »
ok, so i need the 10.95 bell housing?
i have the 10.95 clutch, 11" flywheel from flmopars.....would like to try and get the bellhousing for less than 300, i know that 300 isnt much for this, but you know  :money: doesnt grow on trees
Re: A833 parts list
« Reply #11 on: July 28, 2008 - 09:44:04 AM »
Honestly $300 is probably bets spent on a new one , the ones I saw at Carlisle & elsewhere were $300 used & had stripped holes that needed to be fixed etc , brand new for $300 is a good deal & you know it will not be cracked or damaged
sleepychallenger
Re: A833 parts list
« Reply #12 on: July 28, 2008 - 09:47:25 AM »
ok, which part number there? dont wanna get the wrong one.  :bigsmile:
sleepychallenger
Re: A833 parts list
« Reply #13 on: July 28, 2008 - 09:58:00 AM »
why are the reconditioned and new ones the same price ???
Re: A833 parts list
« Reply #14 on: July 28, 2008 - 10:04:46 AM »
BHR513r is the 4.8 brg retainer
BHR513R-S is the smaller 4.35 brg retainer
not sure if they make the OD 5.2" brg retainer type
