Author Topic: A833 parts list  (Read 24878 times)
Offline fantum
Re: A833 parts list
« Reply #15 on: July 28, 2008 - 10:05:52 AM »
Hey Drew,
I didn't see the legs that mount on the transmission to which you mount the shifter rods, nor did I see any mention of the parts you need to mount the shifter rods to the legs.  Additionally, if you are putting a 4-speed in the car you will need 3 shifter rods (one for 1-2 gears, one for 3-4 gears, and one for reverse).  I also didn't see any mention of the clips you will need to mount the bar that goes from the pedal to the z-bar and the adjuster bar that goes from the z-bar to the clutch fork (which may be part of the adjuster kit).
Also, I hope you have already installed the 4-speed hump in the car.  I am guessing you did, but it's better to ask too many times.
Good luck with the project.
fantum
sleepychallenger
Re: A833 parts list
« Reply #16 on: July 28, 2008 - 10:15:07 AM »
BHR513r is the 4.8 brg retainer
BHR513R-S is the smaller 4.35 brg retainer
not sure if they make the OD 5.2" brg retainer type
I have the 70 sb A833 tranny, so i will need a big block bell housing with some kind of adapter, any advice?
Hey Drew,
fantum
I have not installed the hump yet. i do have it. i have 2 shifter rods, what are the legs? I am not sure on the 3rd rod that i need.
AK450 CLUTCH ADJUSTER KIT 70-1 E/71-2 B BIG BLOCK is the kit that i got from brewers. not sure about the clips that i will need. how many? what type? If anyone wants to come to florida and do the welding for me before i get home, be my guest!!
Re: A833 parts list
« Reply #17 on: July 28, 2008 - 10:36:08 AM »
measure the front brg retainer , it should be 4.35", if so just order the belhousing that matches , there is no difference otherwise between big & small block
sleepychallenger
Re: A833 parts list
« Reply #18 on: July 28, 2008 - 10:52:47 AM »
Alan has the tranny.
Alan, can you check when you can. Thanks
sleepychallenger
Re: A833 parts list
« Reply #19 on: August 01, 2008 - 11:44:50 PM »
 :popcorn: :popcorn: :popcorn:
J/K Alan, when you get time, you know, when you get back to that place where your Cuda is patiently waiting.  :burnout:
Offline IMNCARN82
  • LeDZeP
Re: A833 parts list
« Reply #20 on: August 03, 2008 - 08:00:58 PM »
shifter boot...?  :poopoke: :dunno:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
sleepychallenger
Re: A833 parts list
« Reply #21 on: August 04, 2008 - 10:38:44 AM »
oh yea, cant forget that can i. my list grows, keep it coming guys. i want to ensure i have everything so when i get home i can put it all in and have some fun
Re: A833 parts list
« Reply #22 on: August 04, 2008 - 03:28:27 PM »
Drew, the tranny is out of a small block cuda I think 72 model
sleepychallenger
Re: A833 parts list
« Reply #23 on: August 04, 2008 - 05:04:48 PM »
anyone know the retainer size on that?
Offline Changin Gears
Re: A833 parts list
« Reply #24 on: August 04, 2008 - 06:38:36 PM »
Got to be the 4.35"
sleepychallenger
Re: A833 parts list
« Reply #25 on: August 05, 2008 - 03:06:25 AM »
Thanks man. I will have to order that bell housing then.  :money:
sleepychallenger
Re: A833 parts list
« Reply #26 on: August 07, 2008 - 05:40:12 AM »
any idea on what two shift rods we have? i dont know which one i still need.
Re: A833 parts list
« Reply #27 on: August 07, 2008 - 12:07:23 PM »
do you have a picture ?
sleepychallenger
Re: A833 parts list
« Reply #28 on: August 07, 2008 - 01:07:24 PM »
I dont, Alan has them, he is holding them till i get back from the desert.  :cheers:
Re: A833 parts list
« Reply #29 on: August 07, 2008 - 09:57:06 PM »
OOOPS  he needs the reverse rod and a couple of shift bars
