Author Topic: A833 parts list  (Read 24890 times)
sleepychallenger
Re: A833 parts list
« Reply #45 on: August 13, 2008 - 09:53:09 AM »
this is the flywheel bolts i need right?
BP912 FLYWHEEL BOLT PACKAGE, 6-BOLT CRANK FLANGE Details
Flywheel bolt package, for all 6-bolt crank flanges. 7/16 X 20, package/6 with star washers.
Price: $19.95
sorry for so many questions, just want everything ready when i get home.
sleepychallenger
Re: A833 parts list
« Reply #46 on: August 13, 2008 - 10:35:36 AM »
I like using a 10.5" bellhousing with scalloped pressure plate that allows you to use the 11" clutch.  This not only reduces rotating mass (10.5" vs 11") but reduces overall weight also with the aluminum bellhousing,
You will also need flywheel bolts and a pilot bearing (the Dakota needle bearing version is great).
what size bushing/bearing do i need? brewers is listing different sizes.
Clutch switch start wire harness
what if i dont put this in?
« Last Edit: August 13, 2008 - 10:42:15 AM by sleepychallenger »
Re: A833 parts list
« Reply #47 on: August 13, 2008 - 12:42:47 PM »
the Dakota one is about $20 from Mopar
 the original bushing is about $3 & was the same part for decades
sleepychallenger
Re: A833 parts list
« Reply #48 on: August 13, 2008 - 02:08:08 PM »
thanks. i will have to try and order that.
Re: A833 parts list
« Reply #49 on: August 13, 2008 - 07:30:34 PM »
Drew, I got a factory 3 dollar bushing. You can just put it on your finger like your married to your car. Cause I know you're going to be driving your wife nuts. Your crank should be drilled for the factory bushing, but there's a chance it's not. You can get them local any kind anywhere you are. So hang in there. I put a bearing in mine. Got it from car quest. I got 3 new bushings from car quest in my tool box
sleepychallenger
Re: A833 parts list
« Reply #50 on: August 14, 2008 - 12:54:49 AM »
is there anything that you dont have? other than enough time?  :misbehaving:
will a 68-69 b body shifter work on the ebody or is there a big difference?
« Last Edit: August 15, 2008 - 01:49:20 PM by sleepychallenger »
sleepychallenger
Re: A833 parts list
« Reply #51 on: August 15, 2008 - 04:28:48 PM »
update, im getting close  :dogpile: :bigsmile:
HAVE
transmission hump
Transmission
Clutch kit
clutch bolts
Pedals
CLUTCH PEDAL STUD BRACKET
pedal -> zbar rod
z-bar
11" flywheel
clutch fork
ball stud bracket and ball studs
two shifter rods
clutch adjuster kit from brewers
shifter
shift handle and grips
flywheel bolts
shift grips lense
NEED
10.5" bellhousing   (gonna get it soon from brewers)
shifter mount plate (bidding on ebay)
shifter boot and trim ring (bidding on ebay)
reverse bar (bidding on ebay)
shift rods (bidding on ebay)
correct speedo gear
hardware
new rear tailshaft seal
pilot bearing
tranny to bell housing bolts
bell housing to engine (are they different than the auto trans ones?)
shift plate bolts
shifter to shift plate bolts
do i have to get new front carpet for this? where should i look for this?
« Last Edit: August 16, 2008 - 03:16:54 PM by sleepychallenger »
Re: A833 parts list
« Reply #52 on: August 17, 2008 - 12:34:15 AM »
yes you need a different moulded carpet to cover the tunnel
Re: A833 parts list
« Reply #53 on: August 17, 2008 - 12:37:14 AM »
 :roflsmiley:    The cost goes up n up n up doesnt it drew?
sleepychallenger
Re: A833 parts list
« Reply #54 on: August 17, 2008 - 12:37:54 AM »
 :walkaway: always one more thing. hopefully i will have all the parts soon.
sleepychallenger
Re: A833 parts list
« Reply #55 on: August 17, 2008 - 12:38:49 AM »
it is never going to end. I am getting short in the amount of parts that i need. mostly hardware.
sleepychallenger
Re: A833 parts list
« Reply #56 on: August 17, 2008 - 02:14:42 AM »
HAVE
transmission hump
Transmission
Clutch kit
clutch bolts
Pedals
pedal -> zbar rod
z-bar
11" flywheel
clutch fork
two shifter rods
shifter
flywheel bolts
shift grips lense
reverse bar
NEED
shifter mount plate
correct speedo gear
hardware
pilot bearing
shift plate bolts
carpet
« Last Edit: August 19, 2008 - 08:45:02 AM by sleepychallenger »
sleepychallenger
Re: A833 parts list
« Reply #57 on: August 18, 2008 - 04:18:13 AM »
i thought that i posted more to this, hmmmm.
can someone post pics of the shifter rods and the shifter linkage so that i can see the difference. Also need to see what the shifter legs are. please let me know so that i know what i am looking for.
sleepychallenger
Re: A833 parts list
« Reply #58 on: September 08, 2008 - 01:45:36 PM »
HAVE
transmission hump
Transmission
Clutch kit
clutch bolts
Pedals
pedal -> zbar rod
z-bar
11" flywheel
clutch fork
two shifter rods
shifter
flywheel bolts
shift grips lense
reverse bar
carpet
NEED
shifter mount plate
correct speedo gear
hardware
pilot bearing
shift plate bolts
 :woohoo: got the carpet. now just some little stuff and the bell housing.  :woohoo:  :money:
