*UPDATE*
HAVE
transmission hump
Transmission
Clutch kit
clutch bolts
Pedals
CLUTCH PEDAL STUD BRACKET
pedal -> zbar rod
z-bar
clutch fork
ball stud bracket and ball studs
two shifter rods
clutch adjuster kit from brewers
shifter
shift handle and grips
flywheel bolts
shift grips lense
reverse bar
carpet
bell housing to engine
shift plate bolts (getting from a member)
shifter to shift plate bolts (getting from a member)
shifter boot and trim ring (getting from a member here)
shifter mount plate (getting from a member)
correct speedo gear (told mine will work)
new rear tailshaft seal
pilot bearing
11" flywheel ( new from 440 source)
NEED
10.5" bellhousing
hardware (clips and such)
tranny to bell housing bolts
shifter legs that mount to the tranny.
almost there. the biggest part, bellhousing, will be bought next payday and will be home right before i am.
