Author Topic: A833 parts list  (Read 24876 times)
Re: A833 parts list
« Reply #75 on: October 10, 2008 - 06:48:12 AM »
I saw complete Nos bolt mopar kits on ebay yesterday, but you can use the bell bolts off your automatic that is in your car now. Should be the same bolts buddy. WTG on the bellhousing
sleepychallenger
Re: A833 parts list
« Reply #76 on: October 10, 2008 - 06:57:27 AM »
Thanks. The bolts that hold the tranny to the bell are the same? i am trying to spread my wings  :bigsmile:
Re: A833 parts list
« Reply #77 on: October 10, 2008 - 06:58:21 AM »
 :2thumbs:  Should be.
sleepychallenger
Re: A833 parts list
« Reply #78 on: October 10, 2008 - 07:54:08 AM »
can you think of any other clips?
Re: A833 parts list
« Reply #79 on: October 10, 2008 - 11:55:51 AM »
the engine to belhousing & starter bolts are the same as the Automatic , the bolt that hold the 833 to the belhousing are 7/16 x 1.5" you need 4
sleepychallenger
Re: A833 parts list
« Reply #80 on: October 10, 2008 - 12:40:06 PM »
not a problem, i will order it with the bell housing. thanks
sleepychallenger
Re: A833 parts list
« Reply #81 on: October 15, 2008 - 12:30:49 PM »
 :bananasmi update  :bananasmi
Finally bought the bell housing and bolts. still waiting on word on the shifter legs and clips....
almost there
HAVE
transmission hump
Transmission
Clutch kit
clutch bolts
Pedals
CLUTCH PEDAL STUD BRACKET
pedal -> zbar rod
z-bar
clutch fork
ball stud bracket and ball studs
two shifter rods
clutch adjuster kit from brewers
shifter
shift handle and grips
flywheel bolts
shift grips lense
reverse bar
carpet
bell housing to engine
shift plate bolts (getting from a member)
shifter to shift plate bolts (getting from a member)
shifter boot and trim ring (getting from a member here)
shifter mount plate (getting from a member)
correct speedo gear (told mine will work)
new rear tailshaft seal
pilot bearing
11" flywheel ( new from 440 source)
10.5" bellhousing
tranny to bell housing bolts
NEED
hardware (clips and such)
shifter legs that mount to the tranny.
Offline 72bluNblu
Re: A833 parts list
« Reply #82 on: October 15, 2008 - 03:49:36 PM »
Does your bellhousing still have the clutch fork mount? If not, you'll need it too. I mention it because mine didn't have one...
sleepychallenger
Re: A833 parts list
« Reply #83 on: October 16, 2008 - 07:06:23 AM »
 BH513R-S BIG BLOCK 10.5" BELLHOUSING 1962-1974 A/B/E-BODY, 4.354" RETAINER, NEW Details
NEW reproduction 10.5" big block 356 T-6 heat treated aluminum bellhousing to fit 1962-1974 383/440/426 HEMI A, B & E-Body applications, 4.354" bearing retainer opening, use with 130 tooth flywheel. Bellhousing includes new clutch fork pivot bracket.
it says that it does, but i guess i will find out.
Offline 72bluNblu
Re: A833 parts list
« Reply #84 on: October 16, 2008 - 12:15:21 PM »
Didn't realize you bought it new, it should be there. I bought mine used, and it seems like most of the used ones don't have it anymore.
sleepychallenger
Re: A833 parts list
« Reply #85 on: October 16, 2008 - 01:35:24 PM »
that sucks. did you get on e easy enough?
sleepychallenger
Re: A833 parts list
« Reply #86 on: October 24, 2008 - 09:01:24 AM »
ok guys and gals, i am almost there. I called Alan last night and we found out that i need the swivel adjusters for the shift rods so i will be ordering those this morning and hoping that they get here before wednesday. now that i am home, i will post pictures of all the parts soon.
Drew
Offline hemiken
Re: A833 parts list
« Reply #87 on: October 24, 2008 - 09:03:11 AM »
 :useless:
 :smilielol:
sleepychallenger
Re: A833 parts list
« Reply #88 on: October 24, 2008 - 09:05:51 AM »
wow kenny, your right on it today huh.
sleepychallenger
Re: A833 parts list
« Reply #89 on: October 24, 2008 - 10:02:07 AM »
pics
