update made 13 Aug 08 0339Z
Ok all, not sure if this is the right place or not. I am getting all the parts ready for my 833 swap when i get home. I would like to get a good list of where i am and where i need to be. below is a list of what i have. please respond with what else i need and i will add it to my list.
Transmission
Clutch kit
clutch bolts
Pedals
CLUTCH PEDAL STUD BRACKET
pedal -> zbar rod
z-bar
11" flywheel
clutch fork
ball stud bracket and ball studs
two shifter rods (Alan knows which ones)
clutch adjuster kit from brewers
shifter
shift handle and grips
I think that is it, please help me out. It would be much appreciated....please
I'll start
11" bellhousing
shift grips lense
shifter mount plate
flywheel bolts
pilot bearing
shifter boot
reverse bar
shift rods
Clutch switch start wire harness
correct speedo gear
hardware
new rear tailshaft seal
shifter mounting pad
