I double checked all this stuff when I swapped cams(motor has a 1,000 miles on it). I changed nothing as far as plugs and oil passages go so I'm thinkin' more along the lines of lifters. I think I'll try 20w-50 oil and if that doesn't help, I'll pull the pan and check the oil pump relief spring. Maybe from sitting for 4 months the relief spring could be stuck open?? Maybe a long shot, but it's possible. Thanks for the input, Matt.
