Author Topic: e-body overhead console re-upholstering???  (Read 718 times)
Offline ragtopdodge
« on: July 28, 2008 - 01:42:18 AM »
How do you do this?  Do you have to cut the material in a particular pattern?
I lay the material over it and there's no way to cover it w/o having folds in the material. :help:
 :stomp:
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline miketyler
    • www.miketyler.net
Re: e-body overhead console re-upholstering???
« Reply #1 on: July 28, 2008 - 06:18:48 AM »
The material I used was very "stretchy". I started out with it overlayed on the panel leaving it large. Installed the trim and front bezel and slowly worked down the edges. I dont think I glued the edges, but stretched and glued it on the bottom. I may have had aa wrinkle in one of the front corners but was able to stretch and work it out.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline R/TSE
« Reply #2 on: July 30, 2008 - 02:04:29 AM »
Yup, just streach it out. Use the 3M spray adhesive. Mine ended up with a crease in the front, but you cant see it with the rear view mirror installed
