Author Topic: Electric Fans  (Read 2076 times)
Offline KoolmanDude
  • The Best of both worlds!!
Electric Fans
« on: March 31, 2004 - 07:05:56 AM »
Hello everyone,
I will be changing over to electrical fans for my car soon and needed your input as to what CFM numbers I should be looking for.
The car in question is a 1970 440 Cuda with a 727 tranny with a shift kit in it.
The car will be driving mostly in around 78F weather, will a, let's say, 2900CFM fan do the job without overheating or should I look for bigger numbers?
Any help will be greatly appreciated.
Take care....
Offline GhettoPop
  • I need a new pair of hookers
Re:Electric Fans
« Reply #1 on: March 31, 2004 - 08:34:01 AM »
you can get a duel fan setup.
never seen this but i think it would be a good idea.....the idea of a single pusher and another single puller on the other side of the rad.  wire them seperately so if one fails for any reason, the other will still work, plus u get increased airflow.. maybe its an overkill but an idea.
MOPAR 4 LIFE!
Offline mustardketchup
  • I'm a llama!
Re:Electric Fans
« Reply #2 on: April 15, 2004 - 10:19:30 AM »
Purplehaze,
     Sorry that I can't give you any CFM numbers, but from what I have read on other posting boards, you should only use a puller fan.  The guys who have used electric fans have reported that the pusher fan (in front of the radiator) will restrict airflow into the radiator.
Larry
Offline challenger72rt
  • My l'il girl w' Dodge hat
Re:Electric Fans
« Reply #3 on: April 15, 2004 - 01:17:06 PM »
Personally, I have a puller fan wired to a toggle switch on the dash.  I still use the engine fan, but if things get a little too warm, flick*, there goes the electric fan for added cool.
"Once upon a time I had a really bad Monday"
Offline johnny-d
  • Death is certain, Life is not - think about it
Re:Electric Fans
« Reply #4 on: April 16, 2004 - 06:57:16 AM »
I use a pusher fan on the front of the radiator - there was more clearance on the front side and I don't see any real air flow restrictions. Haven't run the car hard or long enough to see if there will be any overheating problems but I'll keep you posted.
Offline GhettoPop
Re:Electric Fans
« Reply #5 on: April 16, 2004 - 08:26:58 AM »
i used to have an old elec puller fan, i would overheat in nyc traffic.  picked up a 19" flex fan w/ 1 inch spacer and no problems anymore.  dont know the CFM of the elec fan but i think it was pretty weak
MOPAR 4 LIFE!
