Author Topic: Anyone know if this hurst shifter will work in a cuda  (Read 4254 times)
Offline RaptorF229
  • A work in Progress
« on: July 29, 2008 - 12:56:18 AM »
BODY-390431C - 6356
INTERNAL LEVERS- 6353-6354-6355
This is the id in the add.
Offline cudaguy71
Re: Anyone know if this hurst shifter will work in a cuda
« Reply #1 on: August 11, 2008 - 04:02:11 PM »
BODY-390431C - 6356
Yes, E-body...
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
2003 Dodge Dakota Sport
1979 Plymouth Arrow
Offline RaptorF229
« Reply #2 on: August 11, 2008 - 04:10:35 PM »
well a little late to buy it but good to know in the future if I run across another one.
Offline matt63
« Reply #3 on: August 11, 2008 - 05:09:20 PM »
The E body shifter isn't reproduced by Hurst but Brewer's Performance does make it.  I just bought one as my Ebay special was worn out adn rattled.  The E body shifter has 7180 IIRC on the reverse lever.
Matt in Edmonton
'68 Valiant
Offline cudaguy71
« Reply #4 on: August 11, 2008 - 05:21:39 PM »
strange, the one I have came out of a 73 cuda, reverse lever is 6353...   :clueless:
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
1979 Plymouth Arrow
Offline matt63
« Reply #5 on: August 11, 2008 - 05:31:52 PM »
If it works it works.  :)  I asked the guy at Brewers what the difference is between the B body and the E body shifter.  He something about the shift lever offsets.  Perhaps the B body shifter will work.  If there is an issue it might be with the rods hitting the tunnel.
Matt in Edmonton
'68 Valiant
Offline cudaguy71
« Reply #6 on: August 11, 2008 - 05:37:50 PM »
I have two shifters.   The one out of the e-body with reverse # 6353 (according to brewer this is a A/B shifter), the other one I have is out of a 70 B-body with reverse #7174, this lever is about 1/2" longer thatn the #6353.   :dunno:
1973 'Cuda Project
1971 'Cuda Project
1998 Dodge Ram 1500
1979 Plymouth Arrow
Offline RaptorF229
« Reply #7 on: August 11, 2008 - 05:48:19 PM »
I was trying to find a cheap one on eBay.  I think I'll just wait and get it from brewers. It seems that even on eBay the prices are high.
« Reply #8 on: August 11, 2008 - 08:06:13 PM »
2 different ebody yrs shifters right?  70 is a press fit, so it would be a certain number. Then your 73 is a bolt fit so it is a dif num :dunno:
Offline matt63
« Reply #9 on: August 12, 2008 - 09:54:13 AM »
You can have my old one if you like.  It comes with a disassembled Chebby Hurst shifter.  If you are handy you could probably swap some parts over to tighten it up.  It shifted well but rattled under heavy acceleration. I think part of the rattling was caused by the 1/2 rod touching the tunnel although I didn't discover this until I was installing the new shifter with the boot off.
Matt in Edmonton
'68 Valiant
Offline ShelbyDogg
« Reply #10 on: August 12, 2008 - 03:22:20 PM »
I've been lucky. I just bid on different Competition Plus shifters on E-bay, With or without handles till I get one.  Then they all seem to work with a pistol grip and the linkage.  Just don't buy any with welded on handles.  I have a welded on handle that I cut off and made a bolt-on style bracket that I welded on to accept the pistol grip. Looks factory UNDER the boot.   Brewers sells the adapter bushings (for the bigger holes on the shifter to match the e-body rods for $5 a piece)
