Author Topic: Line-Lock not holding?  (Read 7297 times)
nivvy
Re: Line-Lock not holding?
« Reply #30 on: August 01, 2008 - 09:56:58 PM »
makes sense......... as the tires heat up and bite on the rears explains the fuel loading up as it wants to "hook" .. on the fronts the rear tire would spin easier an the motor would rev easier,,,,,,,, and no loading of fuel :working:
Offline RDF
  • The pain that greets me is the stick that beats me
« Reply #31 on: August 01, 2008 - 10:02:46 PM »
Thanks for the vid mike.....and btw, my house STANKS like burning rubber....even after that 2+ mile ride home after that burnout... :roflsmiley:
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
Offline GoodysGotaCuda
« Reply #32 on: August 01, 2008 - 10:06:42 PM »
I probably smell a little like rubber! haha
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline tactransman
« Reply #33 on: August 01, 2008 - 10:24:37 PM »
If you have the line lock on the front brakes,it free's up your left foot so it doesn't have to apply the braking for the front . You build up the front brake pressure,flip the line lock to hold that pressure and do what you want with BOTH feet. You could use it on a four speed also. :cheers:
Terry-tactransman
Union, Mo.
nivvy
« Reply #34 on: August 02, 2008 - 06:43:53 AM »
did someone lose control and go into the grass in those pics....  :scared:
Offline RDF
« Reply #35 on: August 02, 2008 - 07:33:46 AM »
na, it's a dead end road where they are doing lots of construction to extend the road..... :2thumbs:
Bob
1973 'Cuda
My build:
Offline Barracuda4
« Reply #36 on: September 05, 2008 - 09:33:59 PM »
Awesome video...did you ever up the advance at idle and plug the vacuum advance line at the carb?
'74 Cuda 360/727/ 8 3/4
Offline Aracer
« Reply #37 on: September 05, 2008 - 11:13:26 PM »
No, still in the back. Robert kinda worded it funny, front brakes are applied by the pedal, the line-lock blocks fluid flow to the rear.
     Your idea sound interesting, I used to have it on the front, but I removed it after the new calipers, master Cyl. (use the 1974 Fury M/C, its big like the ones on the (1970) 440 E-bodys). It has no residual valves in it, so you can chose the wheel Cyl. with metal cup backers for better hold. I did not like having to plug one front outlet on the Porp.Meter Valve. and teeing the fronts after the line lock. It seems like less fluid would go to the front and unbalance the brake bias, front to back.
     Now the question is, why don't you use the momentary type switch that comes with the Hurst Roll control Kit? And do you find any difference in the pedal resistance as you set the brakes with the lock on?   :chatting:
