Author Topic: yellow head light bulbs  (Read 1873 times)
Offline CrazyPete
« on: July 30, 2008 - 10:42:16 PM »
ive seen more and more challengers with the yellow bulbs on the high beam spot on challengers and thought it might look cool on mine where can i get some?
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
Alaskan_TA
Re: yellow head light bulbs
« Reply #1 on: July 30, 2008 - 10:56:47 PM »
The last set I had came from an electrical supply store.
FYI -the glass locating "nubs" are in a different spot than the stock high beams, so to use the amber fog lamps you need to notch your headlight bucket mounting cups with tin snips.
Offline 71bigblock
    • Steve's Mopars
« Reply #2 on: July 30, 2008 - 10:59:16 PM »
Well, this should help.   :roflsmiley:
Offline CrazyPete
« Reply #3 on: July 30, 2008 - 11:18:23 PM »
 :wow:idk i like it
Offline hotrod98
    • Maniac Musclecars
« Reply #4 on: July 31, 2008 - 09:13:08 PM »
And the yellow headlamps look great too.  ;D
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #5 on: July 31, 2008 - 10:22:23 PM »
tractor supply. Or got to and auto parts store and have them look them up for a tractor using the 4 head lamp automotive lamp dimension for the lamp size. Then you will have to un solder the terminals and resolder them in the proper placement for the plug end. there is also a yellow and a true amber lamp
« Last Edit: July 31, 2008 - 10:23:56 PM by mopardave »
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline CrazyPete
« Reply #6 on: August 01, 2008 - 07:39:21 AM »
 :thumbsup: thanks i'll check out TSC this weekend
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« Reply #7 on: August 04, 2008 - 03:50:50 PM »
Mine are fog lights off some old Volvo.  I paid $5 or $6 for the pair at a junkyard.  They take the removable H3 bulbs.  They were a direct bolt in, the glass locating nubbins were in the right spot, mounting depth was the same as stock, no difference except for the electrical connector, I was able to use to little "jumper" wires to plug into the stock Chrysler connector.
I'll be replacing them soon with aircraft landing lights, I don't get enough fog to need fog lights where I'm at in California.   :scared:
Consider doing the headlight relay upgrade, the voltage drop at the head lights is pretty bad in these 38 year old cars!!
« Last Edit: August 04, 2008 - 03:57:16 PM by RabidScott »
13.9 @ 101 with stock internally 440, OD 4 speed, 3.23 LSD
WaywardGarage.com
Offline CrazyPete
« Reply #8 on: August 04, 2008 - 06:37:34 PM »
thanks for the info its on the "to do" list this winter ive got all the stuff for the rewire already just gonna wait till show season is over
Offline cudax34me
« Reply #9 on: August 04, 2008 - 11:00:22 PM »
"I'll be replacing them soon with aircraft landing lights"
those things really light up the road.dad had some of those in a '62 imperial wagon.the state trooper at the drivers license station told my mom they had to come out.she asked him "why is that? ya'll run em in yor cars".i still laugh wen i remember the look on his face. i gave those to a friend with a '70 el camino. he put them in and flipped out how good they lit up the road.
