Author Topic: Engine Power verses motor mounts  (Read 5987 times)
nivvy
Re: Engine Power verses motor mounts
« Reply #30 on: August 04, 2008 - 02:46:13 PM »
Find a big block kmember... they do make steering kits now that bolt right onto a stock kmember....
cant remember who but i saw them and are nice... pricey though...
The big block kmember will already be setup for a big block to drop in and no tricky convesion small block to big block motor mounts will be needed...
it is right below your oil pan with mounts on it...... ties the front end together ..... look like a K
 :working:
Offline LAA66
« Reply #32 on: August 04, 2008 - 10:59:38 PM »
 Thought to mention, if you decide to stay with the original setup, it's a good idea to reinforce the steering box mounting brackets also.
Offline 71chally416
    • The Streetwalker
« Reply #33 on: August 05, 2008 - 12:17:36 AM »
post up some big pics of your car..... looks like a nice ride and makes power...  :working:
And some time cards please...
« Reply #34 on: August 05, 2008 - 02:26:26 AM »
if you are going to a tubular K look at the CAP one
it is the same part the engine & suspension bolts to & it is the same for All V8s except the Hemi , even the hemi will bolt too it with Schumaker mounts now
Offline BoughtItNew
  • Barracuda
« Reply #35 on: August 05, 2008 - 06:38:57 PM »
I ripped a left mount with my 318 also.  Went to a "Applacian Torque Strap" consisting of a chain from the frame to left cyl head covered by a piece of black 3/4" heater hose.  Just enough slack that it doesn't transmit vibration but keeps the mount from ripping apart under the 399 lbs/ft* torque application on launch!
*As Measured on a chassis dyno @ 3200 RPM
Mike Tritle
DeKalb, IL 60115
Original Owner
74 Barracuda
Purchased Sept. 10, 1974
DesPlaines Chrysler Plymouth
DesPlaines, IL
Offline moper
« Reply #36 on: August 07, 2008 - 07:57:13 AM »
I wouldnt bother with Schumachers. I've repaired several that broke. You want to make sure teh left side ofthe engine can't lift much. I say much, becaseu I dont  like solid mounts. Too much feel for my tastes and it's broken blocks that way. I use about $10 of chain and turnbuckle from my local hardware store on anythignn that runs bigger tires. It's not the power, but the resistance to that power in the form of traction, that loads the mounts. Stock 318s wil lrip brand new India/China/Mexican produced stock mounts. In 4sp cars that can leave you because the Z bar slips off the pivot ball, and the linkage flies apart. (been there personally a bunch before I got smarter). You dont want a solid trans mount, and I dont want a single solid mount.. Because I've had blocks loose ears from them. Maybe tohers dont botl as tight? I dont know. In any case, the chumachers use a U shaped bracket that over time will fatigue and break if you're really making power. Use the interlocking mounts, and you really only need one, or a torque strap that will not hold the engine motionless, but doesnt let it rise more than about 1/2". Drive a fast shaker car with good tires and you'll see how far the engine moves normally. Gliddeen doesnt want the weight of the engine pulling the iron out of shape. When the engien is settled in place, the rear is held by the trans mount, and that 40% of the egnien weight is distributed around the whole bell area. The ears support the remainder 60%. So each mount is really only seeing about 300lbs on the block ears. That's next to nothing, and the position of them (far forward and high on it) means the torque has the least amount of leverage when pulling against them. In the beginning, I'd wagger the only reason they are that far forward (and in the way of steeering) is the clearance required for starter and T bars.
