Author Topic: (Edelbrock) AFB air door counterweight lightening hole location  (Read 1722 times)
Offline FJ5_440
  • Wisconsin
« on: August 01, 2008 - 06:21:15 PM »
I have seen AFB air door counterweights with lightening holes drilled in the locations on the photo below.  What is the best area to remove weight from to get the secondarys in the game sooner?
** Shane **
Offline ntstlgl1970
  • T a c o c a t
Re: (Edelbrock) AFB air door counterweight lightening hole location
« Reply #1 on: August 01, 2008 - 07:06:30 PM »
I don't know where the best place would be to drill. I would start very small though because once the counterweight is too light it is going to bog. IMO - I would make sure you can get a spare easily (or have one on hand) before drilling this one. Might try the race only forum on moparts and ask there since this (to me) is more of a drag racing modification. Or if you have access to the other style edelbrock carb (Thunder series?), I think it has a spring that can be adjusted to control the air door opening rate like on the thermoquads.
« Reply #2 on: August 01, 2008 - 07:54:08 PM »
Since I am Edelbrock stupid... Does that weight rotate from right to left in your picture? If so, then drilling in the red area would decrease resistance at first.
Offline Changin Gears
« Reply #3 on: August 01, 2008 - 11:09:24 PM »
I went down this road once, went too far, had to weld some of 'em back up.
« Reply #4 on: August 02, 2008 - 01:24:11 AM »
Blue is the best location , it is farthest from the shaft / pivot point
Offline Rob C
« Reply #5 on: August 03, 2008 - 10:59:43 AM »
Weigh the door. Then drill hole and re-weigh the door. Keep and track weights.
Of course, this weight will change often when racing.
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
Offline moper
« Reply #6 on: August 06, 2008 - 03:42:17 PM »
I just grind away the edge of the counterweight. It doesnt take much to change it.
