Author Topic: Low fuel light?  (Read 1110 times)
Offline roy282
Low fuel light?
« on: August 02, 2008 - 06:06:34 PM »
Finally have two of the three overhead console lights working :cooldancing: my question is on the low fuel light? There is one fuel wire on the rallye harness and one for the warning light which ties in with the low fuel relay. Do you use both or just one??Thanks!! Rob
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
Offline purplehrtchallenger
Re: Low fuel light?
« Reply #1 on: August 02, 2008 - 07:20:24 PM »
You're almost home!!!    :cheers:
what you got to do now is splice the blue fuel wire into the dash harness blue fuel wire.  According to the schematic, you can do it right at the fuel switch.  What i did was splice the wire into the blue fuel wire at the eight pin connector (connector between the dash harness and the rear harness).  Do this, and all should be good in the world!!
Let me know how it works for you. :crazy:
hope this helps! :drunk:
PHC
