Valve cleaning
Author Topic: Valve cleaning  (Read 715 times)
Offline mikerallye
Valve cleaning
« on: August 02, 2008 - 06:07:19 PM »
I have my intake removed awaiting shipment of its replacement. I  noticed that the valves have some moderate carbon build up on them. Is there anything to spray on them that would clean things up a bit, since they are easy to get to, or is it better to not mess with them?   :clueless:  :clueless:
Re: Valve cleaning
« Reply #1 on: August 03, 2008 - 06:00:51 AM »
Can`t hurt to clean them , not sure what will work best though
nivvy
Re: Valve cleaning
« Reply #2 on: August 03, 2008 - 09:30:43 AM »
BP gas is supposed to clean it.... or just start the motor and pull a plug and fuel wash it  :scared:
I had a plug wire come off one time and when I pulled the 906's that I sold shortly after the whole combustion chamber and those 2 valvs were completely cleaned of deposits...  "Fuel Washed"
I dont think I would recomend doing this. but it works ,,,,,,,  :scared:
Offline Changin Gears
Re: Valve cleaning
« Reply #3 on: August 03, 2008 - 10:20:37 AM »
I agree, I don’t know what you could use because when I clean valves out of the head I have to soak over night in carb cleaner and get physical with them.
Offline 71chally416
    • The Streetwalker
Re: Valve cleaning
« Reply #4 on: August 03, 2008 - 10:41:22 AM »
I've poked deposits on the Intakes valve heads with a long handle flat blade screwdriver before to dislodge carbon buildup when changing intakes. :poopoke: Make sure the valve is closed first so they don't fall in the cylinders. You can suck the chunks out with a shop vac.  :thumbsup:
Offline Rob C
Re: Valve cleaning
« Reply #5 on: August 03, 2008 - 11:01:16 AM »
I have found carb cleaner in a bucket like from NAPA / Auto Zone will do well or break cleaner in a can. A Brass wire brush helps alot.
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
Offline mikerallye
Re: Valve cleaning
« Reply #6 on: August 03, 2008 - 11:31:08 AM »
Wow! info that good should have a price tag on it.   :clapping:
