Author Topic: Replacement Engine harness question....  (Read 1199 times)
Offline wally426ci
    • maryland mopars
« on: August 03, 2008 - 07:45:11 AM »
Does anyone know if I can use the Blue wire with the 90* end on it for electric choke? I think it was used for some sort of Choke item in its time.. I bought the 71 Ebody smallblock harness.... I can take a picture if thats easier.... Or i guess I could do my part and just check voltage to it..  :clueless:
Dont worry guys, Im not cutting any wires this time...  :misbehaving:
 :lol2:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Replacement Engine harness question....
« Reply #1 on: August 03, 2008 - 08:58:54 AM »
Wally,
   I would just turn the key to the "on" position and check for 12 volts between that wire and ground. Since it's blue, it might/could/maybe have 12 volts on it.   :dunno:
« Reply #2 on: August 03, 2008 - 09:08:22 AM »
On my '73 there is a component that mounts on the manifold that gets power from the ignition & sends power to a heater in the choke coil to heat it. I checked the diagrams at mymopar.com & it is spliced to the same wire that feeds the ballast resistor, the '71 diagrams did not show this but it was apparently for a non-electronic ignition. If you get 12V with ignition on & none in the off or accy. position it should be good.
Offline wally426ci
    • maryland mopars
« Reply #3 on: August 03, 2008 - 09:27:05 AM »
Thanks guys!  :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
