Author Topic: Carb help!  (Read 5079 times)
Offline Daves74chally
  • "Yea.... I need another new pair of tires"
Re: Carb help!
« Reply #15 on: August 03, 2008 - 08:10:04 PM »
It looks like a bunch of you guys like that aftermarket cable. How easy is it to install?  could you guys that have them be able to take a few picsfor me. I just wonder how everything hooks up to the carb and the trany. I may beable to shell out a few bucks for it.
1974 Dodge Challenger 414 stroker, 727 trans, 8 3/4 posi [OO/`````\OO]
Buffalo, NY
Offline Ornamental
  • Oslo, Norway
Re: Carb help!
« Reply #16 on: August 03, 2008 - 08:24:28 PM »
The idea is to have that kick down arm almost all the way back when the throttle is wide open. Make sure it doesn't inhibit the throttle opening all the way.
Once you put a tall intake on and/or change the relative throttle cable location on the carb the geometry usually goes to hell.  If you run it without the KD arm you will quickly burn the tranny up because it has no throttle pressure. I avoid all that crap and extend the life of the internals with a manual valve body. The harder it shifts the less the clutch pacs wear.
I'm about to put a Eddy Performer RPM Air Gap on my 340. Guess I might as well just go for the aftermarket cable mentioned by Stroker to avoid future problems...?
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Offline 422STROKER
  • Member Since 6/3/06
Re: Carb help!
« Reply #17 on: August 03, 2008 - 08:32:00 PM »
By tdavist, shot with DSC-P72 at 2008-05-25
You can get a taller bracket from mancini.  I got it and ran this setup for now since i was changing the trans but got the Lokar kit which goes right into this tall bracket as well.  I did a little bending to my 1 piece 2bbl setup and it works perfect just looks like he**.LOL
Tom
Tom
Offline mikerallye
Re: Carb help!
« Reply #18 on: August 03, 2008 - 09:33:40 PM »
From a 71. Can someone ID the carb while we are at it?  :bigsmile:
Offline 71chally416
    • The Streetwalker
Re: Carb help!
« Reply #19 on: August 03, 2008 - 09:46:31 PM »
It's an AVS like came on most every Mopar 4 bbl engine in the 60's.
Offline mikerallye
Re: Carb help!
« Reply #20 on: August 03, 2008 - 10:00:29 PM »
Thanks, my dumb  :swear: threw it away and went through   :swear: learning about Holleys and edelbrocks.   :stirpot:
Re: Carb help!
« Reply #21 on: August 03, 2008 - 10:54:20 PM »
I have an idea.  this is a pic of how far back the kd rod and the throtle on the carb goes.
now maby if I cut into this and made the hole big enough so that I can make the throtle linkage go far back enough.
 :feedback: :feedback:
Just a thought...one of the problems created with the taller intakes is the kick down linkage is too low, with your issue of the linkage being too far forward you could bend the linkage up toward the rear which would effectively shorten it & level it to the carburetor stud.
Offline ntstlgl1970
  • T a c o c a t
Re: Carb help!
« Reply #22 on: August 04, 2008 - 12:16:09 AM »
Here is a pic of the carb end with the kickdown cable and the lokar throttle cable bracket. I don't have a pic of the trans end though, maybe someone else could chime in on that one.
Re: Carb help!
« Reply #23 on: August 04, 2008 - 12:35:32 PM »
Can you guys get me more pics of that kickdown cable setup.  It sounds nice but I need to know what brackets and other parts I should get to if I did end up getting it.
Buffalo, NY
Offline BoughtItNew
  • Barracuda
Re: Carb help!
« Reply #24 on: August 05, 2008 - 06:47:02 PM »
I put a 1/4" bolt and nut in the slot to adjust the kickdown level with my first Holley.  Was able to adjust the upshift point by adjusting the location of the bolt.
I now have a Cheetah forward shift manual valve body which is a whole lot more fun, allows for second gear burnout starts (saves the overrunning clutch) and eliminates the KD linkage.
Mike Tritle
DeKalb, IL 60115
Original Owner
74 Barracuda
Purchased Sept. 10, 1974
DesPlaines Chrysler Plymouth
DesPlaines, IL
Offline BoughtItNew
  • Barracuda
Re: Carb help!
« Reply #25 on: August 05, 2008 - 06:48:35 PM »
See reply number 3 here.  http://www.cuda-challenger.com/cc/index.php?topic=47925.0  It's on an Edelbrock but the outcome is the same.
Mike Tritle
DeKalb, IL 60115
Original Owner
74 Barracuda
DesPlaines, IL
Re: Carb help!
« Reply #26 on: August 08, 2008 - 08:40:09 PM »
Ok so I ended up pulling out the wallet for the KD cable, then I got a new throtle cable with it.  Along with a bracket.  It only took me a couple of hours to install them and man is it nice.
It was so easy. :cooldancing:.  I was soo motivated I went and finished everything off with my new valve covers.
She runs sooo much nicer now :burnout:. Thanks for the sugestions guys :woo:
Buffalo, NY
Offline IMNCARN82
  • LeDZeP
Re: Carb help!
« Reply #27 on: August 08, 2008 - 09:02:08 PM »
 :clapping: :clapping:   LOOKS GREAT!!    Glad she's running better!   So have you seen any performance gain? What's next?      :bigsmile: :wave: :ylsuper:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline mikerallye
Re: Carb help!
« Reply #28 on: August 14, 2008 - 11:29:36 AM »
Where can I get this? What is it called? the bolt that the gas pedel cable connects to. thanks
Re: Carb help!
« Reply #29 on: August 14, 2008 - 11:47:44 AM »
I bought mine from Summit Racing. They have a couple of different sizes. Your's looks like it might be 2 inches?   :clueless:  I think it's called a throttle stud, or carburetor stud   :banghead:
« Last Edit: August 14, 2008 - 12:03:14 PM by MEK-Dangerfield »
