Author Topic: Need Instructions: How to remove & install new Ignition Switch  (Read 10161 times)
Offline Glennster
« on: August 03, 2008 - 10:10:48 PM »
I've got a new ignition switch, I have no idea how to remove the original switch or how to install the new one. It's a 1970 Challenger.
Instructions and help would be GREATLY appreciated!!!!
Thank you!!!!
Re: Need Instructions: How to remove & install new Ignition Switch
« Reply #1 on: August 03, 2008 - 10:27:23 PM »
follow this thread & towards the end I think you will find what you need to know
http://www.cuda-challenger.com/cc/index.php?topic=37458.0
« Reply #2 on: August 03, 2008 - 10:34:46 PM »
Wade...Right when I saw this post , I thought of you first. You are one of the major players here as far as guiding people to the correct search areas on previous post.   WTG :cheers:
Offline Glennster
« Reply #3 on: August 04, 2008 - 05:14:30 AM »
Thank you for the help...
That's a great link you sent me to, educational with some fun along the way.
Again, THANK YOU!!!!!!!!!!!!!
Offline Robco
« Reply #4 on: October 21, 2008 - 11:17:48 AM »
Was the thread for a column mounted ignition switch?  If so, I have a 67 Barracuda with a dash mounted ignition switch, can anyone tell me how to remove this?
:newbie:
« Reply #5 on: October 21, 2008 - 11:19:15 AM »
remove the chrome trim ring & turn the key on then depress the button under the chrome trim ring & the lock will slide out
Offline Robco
« Reply #6 on: October 21, 2008 - 11:59:41 AM »
Is the "button" in the small hole in the dash directly under the ignition switch?  Another stupid question, how do you remove the chrome trim ring?  Is there a clip to remove back of the switch under the dash?  Thanks.
« Reply #7 on: October 21, 2008 - 11:09:04 PM »
unthread the chrome retainer using needle nose pliers , remove the lock from the dash & swing it down under the dash , turn the lock on , there is a small button in the threads , depress that & the lock will pull out
Offline Robco
« Reply #8 on: October 21, 2008 - 11:41:49 PM »
Okay, I got it.  The ring has four small indentations that I almost didn't see.  I unscrewed that off of the ignition switch.  Thanks. :2thumbs:
« Reply #9 on: October 21, 2008 - 11:52:53 PM »
Great  :2thumbs:
