Author Topic: Shaker question  (Read 870 times)
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Shaker question
« on: August 04, 2008 - 01:37:33 PM »
I am not sure if this would go under the engine section or body section, so I put it here.  Since I just purchased a flat hood for my Challenger, I have been thnking about gathering up parts to make a shaker hood/engine.  I was wondering: can I still keep my current intake and carb (both Edelbrock) and install the original looking Shaker parts without much trouble?  Or do I have to have custom parts to make it work?
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Shaker question
« Reply #1 on: August 04, 2008 - 01:54:08 PM »
Is it a big block or small block and which edelbrock intake?
1996 Dodge Viper GTS Coupe
nivvy
Re: Shaker question
« Reply #2 on: August 04, 2008 - 02:14:39 PM »
I belive he runs a 360   :working:
Offline Jacksboys
Re: Shaker question
« Reply #3 on: August 06, 2008 - 02:05:09 AM »
Yep, I have it listed right above my picture  :2thumbs:
I have the RPM (non-airgap) intake and 600cfm carb (I think #1406).  I might switch to a 750cfm in the future, if that helps.
Re: Shaker question
« Reply #4 on: August 06, 2008 - 02:18:12 AM »
you may be able to get away with a shorter base as used on a 440 4 bbl & the taller intake
Offline Jacksboys
Re: Shaker question
« Reply #5 on: August 06, 2008 - 02:33:53 AM »
I did not even think about that.  Do you know the difference in height between the bases?
Offline dandsgcuda
  • almost there
Re: Shaker question
« Reply #6 on: August 06, 2008 - 10:19:41 AM »
I have the rpm intake on mine.Iused a drop down air cleaner and attached a 1/8 aluminum plat to it to make the carb base plate.I bought a fiberglass adapter ring and use a 2'' air cleaner .Ithink I have a total of $40.00 dollars into it and it works great.
Re: Shaker question
« Reply #7 on: August 06, 2008 - 11:52:35 AM »
contact Ben Snobar , he should be able to help especially if you have the intake height
Offline Jacksboys
Re: Shaker question
« Reply #8 on: August 06, 2008 - 03:51:28 PM »
You have a pm.
Who is Ben Snobar?  :dunno:
Offline Jacksboys
