Author Topic: Need some 4-speed/conversion advice/suggestions!  (Read 6806 times)
Offline GoodysGotaCuda
« on: August 04, 2008 - 08:53:25 PM »
guy i ran into is selling the following from his '70 340 Duster:
Lakewood Bell
4speed trans out of the '70 340 duster
'Super shift' Hurst shifter (said it would accept a pistol grip which is what i'd run)
40# billet flywheel
13# "Hays" flywheel
Hays 3,000lb diaphram 10.5" clutch
reinforced stock clutch fork
z-bar also reinforced
large u-joint driveshaft
It is missing the linkage besides the z-bar, and the pedal assembly he says. I would also need the 4-speed floor hump.
He is asking $950 for the setup, comments?
Also will the abody driveshaft work in my E?
Thanks! :bigsmile:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: Need some 4-speed/conversion advice/suggestions!
« Reply #1 on: August 04, 2008 - 08:56:34 PM »
Mike if you have a 727, then your drive shaft will work. The trans is for an a body not e body. The bellhousing would work, but I have a correct bellhousing for your car. You would do better to keep looking. Even the torq bar is different
« Reply #2 on: August 04, 2008 - 08:59:53 PM »
I have a 904 right now with the large u-joint 3rd member. How is the trans different, and it is unuseable in my ebody?
Thanks Al-
1976 Dodge Warlock
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #3 on: August 04, 2008 - 09:12:45 PM »
Here is some pic's I stole from E-Bay . The E-Body has a long tail shaft and the A-Body has a short shaft.
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline Changin Gears
« Reply #4 on: August 04, 2008 - 09:27:48 PM »
Even if this was e-body stuff I would pass, sounds like it was hammered pretty hard.
« Reply #5 on: August 04, 2008 - 09:30:57 PM »
Ah well, thanks for the info!  :bigsmile: My auto is limping around as it sits and am trying to keep my eye out on a decent deal. Rather let it sit broken than spend more money on this automatic  :swear:
I miss ->  :burnout:
1976 Dodge Warlock
Offline vinb
« Reply #6 on: August 04, 2008 - 09:34:15 PM »
Mike, no good ..
The only thing you can use is the bellhousing and maybe the shifter only,  the rods are different also..
But you can always fine a nice A-body car to put it in...(67-68-69 Cuda)...
« Reply #7 on: August 04, 2008 - 09:42:47 PM »
Goodyman, I figure a ace mechanic such as yourself would be working one of these newfangled 5 or 6 speed setups into your hot-rod... If Kiesler can make a kit all the parts are out there.
« Reply #8 on: August 04, 2008 - 09:53:33 PM »
Kiesler = Big $$$! I'd love to do a 5-speed even more so, however the cost is through the roof for a 'kit' ($4,000-$5,000 range). I lack in fabrication skills, which I have zero of! So currently i'm vulnerable to 'kits' and pre-figured things. Many 'variables' with aftermarket transmissions though, pilot bushing, flywheel, clutch, bellhousing, linkage, size/location, shifter location, etc, etc. Not saying I would have to buy kiesler's kit in entirety, stuff like a hyd clutch and such I bet I could fend for myself, the rest for a 5speed is almost best left to 'those that have been there, and built it'. I'd like a new gen Hemi in my car someday, 5speed would be perfect....can't have everything at once, I start my career the first of the year...we'll see how things pan out.  :cheers:
'Perfect' setup would be a turbo 5.7, 5speed, independant rear and some gnarly brakes  :drool:
« Last Edit: August 04, 2008 - 10:05:05 PM by GoodysGotaCuda »
1976 Dodge Warlock
« Reply #9 on: August 05, 2008 - 02:22:16 AM »
 almost nothing there you can use belhousing fork & 40# flywheel is all , everything else is different
« Reply #10 on: August 05, 2008 - 10:49:57 AM »
Just being curious I got a quote from Keisler for a TKO-600 full conversion from my auto $5,300  :faint: :faint: :faint: :faint:
Brewer's told me $3,700 for a full manual swap with a rebuilt 4-speed, linkage and the whole works..but you're still dealing with old technology and no o/d. I'd easily go the extra $1,600 for the Keisler if I could afford either. Thats still a LOT of money for a trans!  :money:
« Last Edit: August 05, 2008 - 10:55:19 AM by GoodysGotaCuda »
1976 Dodge Warlock
Offline RaptorF229
  • A work in Progress
« Reply #11 on: August 05, 2008 - 11:03:09 AM »
goody I'm in the same boat. I'm finding deals piece by piece. So far I have the tranny, bell, flywheel, and 4speed console. So far I've spent about 600. Look on craigslist.
« Reply #12 on: August 05, 2008 - 11:05:04 AM »
Good deal, good luck with your swap! Sticking with a 4speed or more?
1976 Dodge Warlock
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #13 on: August 05, 2008 - 11:57:04 AM »
What about a Passons OD A833, if your not wanting to go full expense 5sp or would the cost be similar as above?
Don
Member Since January 14, 2002
« Reply #14 on: August 05, 2008 - 12:24:41 PM »
From what i've looked up their gear ratios aren't very good for aggressive driving. Seems like more of a 'cruising' setup with o/d. pros and cons to all of 'em i guess, but the cost is lower!
1976 Dodge Warlock
