Author Topic: Need some 4-speed/conversion advice/suggestions!  (Read 6804 times)
Offline GoodysGotaCuda
Re: Need some 4-speed/conversion advice/suggestions!
« Reply #30 on: August 07, 2008 - 12:30:25 PM »
Thanks for the info, there are a couple trucks in the local pull a part according to their website. I will have to go by and pray there is a 4spd there. What parts are interchangeable with an ebody? Trans and bell? Anything else? Should I grab the fly?
Thanks!
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #31 on: August 07, 2008 - 01:02:13 PM »
trans, bell , shifter , flywheel ,release fork ,slip yolk
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« Reply #32 on: August 07, 2008 - 02:55:40 PM »
Chryco was the guy who helped me put my first OD tranny behind a B/RB engine, about 6 or 7 years ago, and ever since then I use them exclusively.  I've put 'em in Mopar A, B, and E bodies, and one into my Model A when it was running a 383 Mopar with 4.88 rear gears.  Wild!!
Except for the gear sets and some small parts internally, ALL 23 spline A-833 transmissions are the same from '66 to '88.  They even put the A-833 in some Chevy trucks and vans, but those use a different main case than the Mopar units.
The one main difference is the input bearing retainer will need to be turned down a bit on a lathe, any machine shop should be able to handle that.  I just use my buddy's lathe, it's pretty simple.
The only Chrysler four speed I've ever hurt was an OEM cast iron 23 spline unit from a '68 Charger 383 4 barrel car, and even then it was only the synchro for first (I think).  I've never destroyed a later model unit.  My buddy with a 489 cube stroked 383 in a '66 Belvedere with 3.91s uses one, along with an aluminum flywheel, and that thing has assloads of torque.
As far as aluminum flywheels go, I love those too.  Feels a little less "torquey" off the line, but the way it revs up incredibly fast it well worth it.
1970 Dodge Challenger
13.9 @ 101 with stock internally 440, OD 4 speed, 3.23 LSD
WaywardGarage.com
« Reply #33 on: August 07, 2008 - 11:36:40 PM »
if you use a belhousing from the truck the retainer is already the same size as the bell this is the advantage with the small block , the big block never had the 5.2" hole in the bell so the retainer has to be trimmed down  .
